NXP技术解决方案
2146|1
 楼主| 想实习去 发表于 2009-12-16 13:11 | 显示全部楼层 |阅读模式
NXP, TE, TI, IO, AN
iPod Car audio Mate
Transmit the iPod music to car audio by FM radio, no extra installation work. Display FM frequency on the big iPod screen. Wireless control your iPOD by 2.4G wireless remote mounted on steering wheel.
Technical Specifications·
Dimensions: 1.65" x 1.23" x 0.5" (40.5mm x 28.5mm x 8mm)
Weight: 0.6 oz
Built-in antenna
Power requirement: With mini USB connector for battery charging and connecting to PC
External Power:
Hole for car cigarette charger adapter (optional)
Display : FM frequency display in the IPod display, better for reading, no LCD built in to save power.
Control : wheel knob on right side
Modulation: FM Stereo
Frequencies: 76.0.-108.0MHz , Worldwide use
High stability crystal oscillator, Digital PLL technology, stable FM transmitting frequency. No frequency drifting.
Frequency response: 50Hz to 20KHz
Operating range: 10-30 ft
FCC compliant: (FCC ID # : xxxxx)
Supports all iPod models.
6019实验室 发表于 2009-12-16 13:13 | 显示全部楼层
真是牛,一个端子就搞定无线传输,这个东西大大的前途啊!
