[ZLG-MCU] C语言宏定义技巧(转)
1737|4
 楼主| xiaoxin1986 发表于 2009-12-22 10:53 | 显示全部楼层 |阅读模式
C语言宏定义技巧(常用宏定义)
写好C语言,漂亮的宏定义很重要,使用宏定义可以防止出错,提高可移植性,可读性,方便性 等等。下面列举一些成熟软件中常用得宏定义。。。。。。
1,防止一个头文件被重复包含
#ifndef COMDEF_H
#define COMDEF_H
//头文件内容
#endif
2,重新定义一些类型,防止由于各种平台和编译器的不同,而产生的类型字节数差异,方便移植。
typedef unsigned char     boolean;   /* Boolean value type. */
typedef unsigned long int uint32;     /* Unsigned 32 bit value */
typedef unsigned short   uint16;     /* Unsigned 16 bit value */
typedef unsigned char     uint8;     /* Unsigned 8 bit value */
typedef signed long int   int32;     /* Signed 32 bit value */
typedef signed short     int16;     /* Signed 16 bit value */
typedef signed char     int8;     /* Signed 8 bit value */
//下面的不建议使用
typedef unsigned char   byte;       /* Unsigned 8 bit value type. */
typedef unsigned short   word;       /* Unsinged 16 bit value type. */
typedef unsigned long   dword;     /* Unsigned 32 bit value type. */
typedef unsigned char   uint1;     /* Unsigned 8 bit value type. */
typedef unsigned short   uint2;     /* Unsigned 16 bit value type. */
typedef unsigned long   uint4;     /* Unsigned 32 bit value type. */
typedef signed char     int1;       /* Signed 8 bit value type. */
typedef signed short     int2;       /* Signed 16 bit value type. */
typedef long int       int4;       /* Signed 32 bit value type. */
typedef signed long     sint31;     /* Signed 32 bit value */
typedef signed short     sint15;     /* Signed 16 bit value */
typedef signed char     sint7;     /* Signed 8 bit value */
3,得到指定地址上的一个字节或字
#define MEM_B( x ) ( *( (byte *) (x) ) )
#define MEM_W( x ) ( *( (word *) (x) ) )
4,求最大值和最小值
  #define MAX( x, y ) ( ((x) > (y)) ? (x) : (y) )
  #define MIN( x, y ) ( ((x) < (y)) ? (x) : (y) )
5,得到一个field在结构体(struct)中的偏移量
#define FPOS( type, field ) \
/*lint -e545 */ ( (dword) &(( type *) 0)-> field ) /*lint +e545 */
6,得到一个结构体中field所占用的字节数
#define FSIZ( type, field ) sizeof( ((type *) 0)->field )
7,按照LSB格式把两个字节转化为一个Word
#define FLIPW( ray ) ( (((word) (ray)[0]) * 256) + (ray)[1] )
8,按照LSB格式把一个Word转化为两个字节
#define FLOPW( ray, val ) \
(ray)[0] = ((val) / 256); \
(ray)[1] = ((val) & 0xFF)
9,得到一个变量的地址(word宽度)
#define B_PTR( var ) ( (byte *) (void *) &(var) )
#define W_PTR( var ) ( (word *) (void *) &(var) )
10,得到一个字的高位和低位字节
#define WORD_LO(xxx) ((byte) ((word)(xxx) & 255))
#define WORD_HI(xxx) ((byte) ((word)(xxx) >> 8))
11,返回一个比X大的最接近的8的倍数
#define RND8( x )     ((((x) + 7) / 8 ) * 8 )
12,将一个字母转换为大写
#define UPCASE( c ) ( ((c) >= 'a' && (c) <= 'z') ? ((c) - 0x20) : (c) )
13,判断字符是不是10进值的数字
#define DECCHK( c ) ((c) >= '0' && (c) <= '9')
14,判断字符是不是16进值的数字
#define HEXCHK( c ) ( ((c) >= '0' && (c) <= '9') ||\
              ((c) >= 'A' && (c) <= 'F') ||\
((c) >= 'a' && (c) <= 'f') )
15,防止溢出的一个方法
#define INC_SAT( val ) (val = ((val)+1 > (val)) ? (val)+1 : (val))
 楼主| xiaoxin1986 发表于 2009-12-22 10:54 | 显示全部楼层
16,返回数组元素的个数
#define ARR_SIZE( a ) ( sizeof( (a) ) / sizeof( (a[0]) ) )
17,返回一个无符号数n尾的值MOD_BY_POWER_OF_TWO(X,n)=X%(2^n)
#define MOD_BY_POWER_OF_TWO( val, mod_by ) \
      ( (dword)(val) & (dword)((mod_by)-1) )
18,对于IO空间映射在存储空间的结构,输入输出处理
#define inp(port)       (*((volatile byte *) (port)))
#define inpw(port)     (*((volatile word *) (port)))
#define inpdw(port)     (*((volatile dword *)(port)))
#define outp(port, val)   (*((volatile byte *) (port)) = ((byte) (val)))
#define outpw(port, val) (*((volatile word *) (port)) = ((word) (val)))
#define outpdw(port, val) (*((volatile dword *) (port)) = ((dword) (val)))
[2005-9-9添加]
19,使用一些宏跟踪调试
A N S I标准说明了五个预定义的宏名。它们是:
_ L I N E _
_ F I L E _
_ D A T E _
_ T I M E _
_ S T D C _
如果编译不是标准的,则可能仅支持以上宏名中的几个,或根本不支持。记住编译程序
也许还提供其它预定义的宏名。
_ L I N E _及_ F I L E _宏指令在有关# l i n e的部分中已讨论,这里讨论其余的宏名。
_ D AT E _宏指令含有形式为月/日/年的串,表示源文件被翻译到代码时的日期。
源代码翻译到目标代码的时间作为串包含在_ T I M E _中。串形式为时:分:秒。
如果实现是标准的,则宏_ S T D C _含有十进制常量1。如果它含有任何其它数,则实现是
非标准的。
可以定义宏,例如:
当定义了_DEBUG,输出数据信息和所在文件所在行
#ifdef _DEBUG
#define DEBUGMSG(msg,date) printf(msg);printf(“%d%d%d”,date,_LINE_,_FILE_)
#else
#endif
20,宏定义防止使用是错误
用小括号包含。
例如:#define ADD(a,b) (a+b)
用do{}while(0)语句包含多语句防止错误
例如:#difne DO(a,b) a+b;\
            a++;
应用时:if(….)
      DO(a,b); //产生错误
    else
解决方法: #difne DO(a,b) do{a+b;\
            a++;}while(0)
宏中"#"和"##"的用法
一、一般用法
我们使用#把宏参数变为一个字符串,用##把两个宏参数贴合在一起.
用法:
#include<cstdio>
#include<climits>
using namespace std;
#define STR(s)   #s
#define CONS(a,b) int(a##e##b)
int main()
  printf(STR(vck));       // 输出字符串"vck"
  printf("%d
", CONS(2,3)); // 2e3 输出:2000
  return 0;
二、当宏参数是另一个宏的时候
需要注意的是凡宏定义里有用'#'或'##'的地方宏参数是不会再展开.
1, 非'#'和'##'的情况
#define TOW     (2)
#define MUL(a,b) (a*b)
printf("%d*%d=%d
", TOW, TOW, MUL(TOW,TOW));
这行的宏会被展开为:
printf("%d*%d=%d
", (2), (2), ((2)*(2)));
MUL里的参数TOW会被展开为(2).
2, 当有'#'或'##'的时候
#define A       (2)
#define STR(s)   #s
printf("int max: %s
", STR(INT_MAX));   // INT_MAX #include<climits>
这行会被展开为:
printf("int max: %s
", "INT_MAX");
printf("%s
", CONS(A, A));           // compile error
这一行则是:
printf("%s
", int(AeA));
INT_MAX和A都不会再被展开, 然而解决这个问题的方法很简单. 加多一层中间转换宏.
加这层宏的用意是把所有宏的参数在这层里全部展开, 那么在转换宏里的那一个宏(_STR)就能得到正确的宏参数.
#define A       (2)
#define _STR(s)   #s
#define STR(s)     _STR(s)       // 转换宏
#define _CONS(a,b) int(a##e##b)
#define CONS(a,b)   _CONS(a,b)     // 转换宏
printf("int max: %s
", STR(INT_MAX));       // INT_MAX,int型的最大值,为一个变量 #include<climits>
输出为: int max: 0x7fffffff
STR(INT_MAX) --> _STR(0x7fffffff) 然后再转换成字符串;
printf("%d
", CONS(A, A));
输出为:200
CONS(A, A) --> _CONS((2), (2)) --> int((2)e(2))
三、'#'和'##'的一些应用特例
1、合并匿名变量名
#define ___ANONYMOUS1(type, var, line) type var##line
#define __ANONYMOUS0(type, line) ___ANONYMOUS1(type, _anonymous, line)
#define ANONYMOUS(type) __ANONYMOUS0(type, __LINE__)
例:ANONYMOUS(static int); 即: static int _anonymous70; 70表示该行行号;
第一层:ANONYMOUS(static int); --> __ANONYMOUS0(static int, __LINE__);
第二层:                 --> ___ANONYMOUS1(static int, _anonymous, 70);
第三层:                 --> static int _anonymous70;
即每次只能解开当前层的宏,所以__LINE__在第二层才能被解开;
2、填充结构
#define FILL(a)   {a, #a}
enum IDD{OPEN, CLOSE};
typedef struct MSG{
IDD id;
const char * msg;
}MSG;
MSG _msg[] = {FILL(OPEN), FILL(CLOSE)};
相当于:
MSG _msg[] = {{OPEN, "OPEN"},
        {CLOSE, "CLOSE"}};
3、记录文件名
#define _GET_FILE_NAME(f)   #f
#define GET_FILE_NAME(f)   _GET_FILE_NAME(f)
static char FILE_NAME[] = GET_FILE_NAME(__FILE__);
4、得到一个数值类型所对应的字符串缓冲大小
#define _TYPE_BUF_SIZE(type) sizeof #type
#define TYPE_BUF_SIZE(type)   _TYPE_BUF_SIZE(type)
char buf[TYPE_BUF_SIZE(INT_MAX)];
  --> char buf[_TYPE_BUF_SIZE(0x7fffffff)];
  --> char buf[sizeof "0x7fffffff"];
这里相当于:
char buf[11];
beny5566 发表于 2009-12-22 12:45 | 显示全部楼层
谢谢分享,
学习了。
