SPI1重映射问题
3513|4
jeson_luo|  楼主 | 2009-12-23 10:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大虾好,
下面这个是我用的SPI1的重映射,我的SD卡SPI通信口就是链接到这几个口上面的,在调用Mass_Storage_Start ();函数时总是检测不到SD卡,能帮我看下void SPI_Config(void)程序什么问题?谢谢!
void Mass_Storage_Start (void)
  /* Disble the JoyStick interrupts */
  IntExtOnOffConfig(DISABLE);
  /* Clear the OLED screen */
  //OLED_Clear(White);
  /* Set the Back Color */
  OLED_SetBackColor(Blue);
  /* Set the Text Color */
  OLED_SetTextColor(White);
  if(MSD_Init() != 0x00)
    OLED_DisplayStringLine(Line0, "Warning ");
    OLED_DisplayStringLine(Line1, "   NO   ");
    OLED_DisplayStringLine(Line2, "SD Card ");
    OLED_DisplayStringLine(Line3, "Pres SEL");
    /* Loop until SEL key pressed */
    while(ReadKey() != SEL)
  else
    Get_Medium_Characteristics();
    OLED_Clear(White);
    /* Display the "  Plug the USB   " message */
    OLED_DisplayStringLine(Line1, "  Plug  ");
    OLED_DisplayStringLine(Line2, "USB Cable");
    /* Intialize the USB cell */
    USB_Init();
    //OLED_ClearLine(Line9);
    /* Display the "To stop Press SEL" message */
    //OLED_DisplayStringLine(Line8, "  To stop Press SEL ");
    PowerOff();
  OLED_Clear(White);
  //DisplayMenu();
  IntExtOnOffConfig(ENABLE);
  /* Flush SPI1 Data Register */
  SPI_ReceiveData(SPI1);
  GPIO_InitTypeDef  GPIO_InitStructure;
  SPI_InitTypeDef   SPI_InitStructure;
  /* GPIOB Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
  /* SPI1 Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  /* Configure SPI1 output pins: SCK, MISO and MOSI */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* Configure SPI1 input pin: MISO */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* Configure PB6 pin: CS pin */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  /* SPI1 Periph Remap */
  GPIO_PinRemapConfig(GPIO_Remap_SPI1, ENABLE);
  /* SPI1 Config */
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI1, &SPI_InitStructure);
  /*Enable SPI1.NSS as a GPIO*/
  //SPI_SSOutputCmd(SPI1, ENABLE);
  /* SPI1 enable */
  SPI_Cmd(SPI1, ENABLE);
司徒老鹰| | 2009-12-23 19:10 | 只看该作者
好长的码……还是小字,看的好费劲啊
hsbjb| | 2009-12-23 22:01 | 只看该作者
是啊,字体弄大点嘛
ST_ARM| | 2009-12-24 09:30 | 只看该作者
SPI的MISO也要配置为AF_PP:
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
估计你没有仔细看参考手册和STM32的软件库的例程,自说自画就认为MISO要设置为输入口。
bear1| | 2014-12-16 21:58 | 只看该作者
ST_ARM 发表于 2009-12-24 09:30
SPI的MISO也要配置为AF_PP:
  GPIO_InitStructur ...
AF_PP,复用推挽输入?
