Virtex-4 FX ML410 Embedded Development Platform
2715|0
 楼主| jameswangchip 发表于 2009-12-25 17:35 | 显示全部楼层 |阅读模式
Virtex-4 FX ML410 Embedded Development Platform 点击放大图片
$2,995.00
器件编号:HW-V4-ML410-UNI-G
文档支持器件系列
  • Virtex-4 FX
The ML410 is a RoHS compliant embedded development platform based on the Xilinx Virtex®-4 XC4VFX60 FPGA. Software and Hardware development teams can take advantage of the FPGA’s dual PowerPC® 405 processors, a generous amount of FPGA fabric, and I/O capabilities that extend from the low bit rate UARTs to the high speed RocketIO™ Multi-Gigabit Transceivers (MGTs). When paired with the Xilinx Embedded Development Kit (EDK), and its catalog of IP peripherals, the ML410 can be used to rapidly prototype and verify system designs. Software applications using either standalone code or targeting an operating system, such as VxWorks, can also be created.
其中包含:
  • ML410 board (ATX form factor)
  • XC4VFX60-11FFG1152CES4S FPGA
  • 512 MB CompactFlash card
  • 256 MB DDR2 DIMM
  • LCD character display and cable
  • ATX power supply
关键特性
  • XC4VFX60-11FFG1152 FPGA
  • ATX form factor motherboard
  • 32-bit component DDR memory (64 MB) and 64-bit DDR2 DIMM (256 MB)
  • 512 MB CompactFlash (CF) card and System ACE CF controller for configuration
  • Two on-board 10/100/1000 Ethernet PHYs (MII/RGMII and SGMII) with RJ-45 connectors
  • Two PCI Express downstream connectors
  • Four 32-bit/33 MHz PCI connectors (Two 3.3V slots and two 5V slots)
  • ALi South Bridge SuperIO controller
  • Two USB peripheral ports and one parallel port
  • Two serial ATA connectors
  • Two UARTs with RS-232 connectors
  • Xilinx Personality Module (XPM) interface
  • JTAG and trace debug ports
  • IIC/SMBus interface
  • SPI EEPROM
  • General purpose I/O (GPIO)
  • Flash memory interface
  • VGA graphics interface
  • LEDs, LCD, and switches
  • Encryption battery
  • Fan controller
  • PS/2 mouse and keyboard connectors
  • 3.5mm headphone and microphone connectors
目标应用
  • Markets: Industrial, Telecom / Datacom, Medical, Military / Aerospace
  • Applications: Data Transmission and Manipulation, Digital Video, Embedded Microprocessor, Bus Interface, High Speed Design, Telecom / Datacom
地址:北京市海淀区知春路128号泛亚大厦1892B
邮编: 100086
电话:010-82626934,82627105
传真:010-51664726
联系人: 李先生( RICHIE LEE)
Http://www.bluechipsemi.com
个人签名:新浪微博:阿牛哥在北京 http://www.weibo.com/brotherbull QQ:1047177125
2860
