tim1是否能输出互为180度的PWM?
18129|61
 楼主| junsi 发表于 2009-12-25 21:07 | 显示全部楼层 |阅读模式
一个项目需要输出两路PWM,但要互为180度相位,看了关于tim1定时器的文档,还是不明白,请高手指点?
lxyppc 发表于 2009-12-28 17:49 | 显示全部楼层
个人更倾向于使用PWM1,PWM2的方式,因为Toggle(翻转)模式需要考虑Channel的初始状态
需要在Toggle开始前强制设定两个Channel的相位,曾经产品上就出现过这样的问题(相同的HEX,运行时产生不同的结果)
根据香主的提示写的一段能满足楼主要求的代码
  软件: IAR 4.42 32K 限制版
  库:   2.0
  硬件: 万利 EKSTM3210B-LK1
  说明: 使用TIM3的Channel3和Channel4产生楼主所述波形
#define   Fsys           72000000ul   //  system freq 72MHz
#define   Fpwm           20000        //  PWM freq  20K
#define   PWM_DUTY       20           //  PWM duty 20%
void  ConfigTimer(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  RCC_APB1PeriphClockCmd(  RCC_APB1Periph_TIM3,ENABLE);
  RCC_APB2PeriphClockCmd(  RCC_APB2Periph_GPIOB,ENABLE);
  TIM_DeInit(TIM3);
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1;
  TIM_TimeBaseStructure.TIM_Period = (Fsys/2) / Fpwm;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputState_Disable;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OCInitStructure.TIM_Pulse = (((Fsys/2) / Fpwm) * PWM_DUTY) / 100;
  TIM_OC3Init(TIM3,&TIM_OCInitStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM_OCInitStructure.TIM_Pulse = (((Fsys/2) / Fpwm) * (100-PWM_DUTY)) / 100;
  TIM_OC4Init(TIM3,&TIM_OCInitStructure);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  TIM_CtrlPWMOutputs(TIM3, ENABLE);
  TIM_Cmd(TIM3,ENABLE);
无图无真相。图中CH3即 Timer3 Channel3(GPIOB.0), CH4即 Timer3 Channel4(GPIOB.1)
评分
参与人数 2威望 +9 收起 理由
kk5290122 + 5 很给力!
香水城 + 4
查看全部评分
lxyppc 发表于 2009-12-25 21:19 | 显示全部楼层
可以的,一个PWM模式1,一个PWM模式2
 楼主| junsi 发表于 2009-12-25 21:21 | 显示全部楼层
:)好的,我先研究下,多谢
香水城 发表于 2009-12-25 21:28 | 显示全部楼层
STM32的TIM1有三对互补输出,使能互补输出直接产生互为180度相位的2路PWM输出。
如果不使用TIM1,可以用2楼的办法。
 楼主| junsi 发表于 2009-12-25 21:44 | 显示全部楼层
香主理解错我的意思了,我说的180度相位差是对整个pwm周期说的,跟互补输出是不同的,我还在研究2楼说的。。。
香水城 发表于 2009-12-25 21:51 | 显示全部楼层
也许是我理解错了,你能画个波形图出来吗?这样比较直观。
还有你要的PWM输出的占空比是多少?是常量还是变量?如果是变量,在什么范围变化?
想了想,占空比似乎不能大于50%,否则不能满足互为180度相位的要求,不知对不对,恐怕看了波形图才能知道。
香水城 发表于 2009-12-25 21:59 | 显示全部楼层
如果占空比刚好是50%,则这2路信号应该刚好为互补信号。不知对不对,恐怕看了波形图才能知道。
 楼主| junsi 发表于 2009-12-25 23:49 | 显示全部楼层
我画了一个示意图。我想要pwm的展空比是任意可调的
lxyppc 发表于 2009-12-26 14:32 | 显示全部楼层
楼主,看了你上面的图之后,我在2楼说的不能解决你的这个问题
用两个TIMER可以实现这种波形的输出
violit 发表于 2009-12-26 19:21 | 显示全部楼层
互补的PWM,好像使用TIM2、3也都可以的
TIM1的主要优势是可以生成带有死区的互补PWM
香水城 发表于 2009-12-26 21:05 | 显示全部楼层
这个问题要好好考虑一下。
03024003 发表于 2009-12-28 14:35 | 显示全部楼层
楼主 你的问题解决没
我现在也到了和你的需求类似的问题
香水城 发表于 2009-12-28 16:18 | 显示全部楼层
考虑了一下,使用STM32 的任意一个定时器都可以实现楼主的要求。
基本设置如下:
1)配置定时器的计数器为中间对齐计数,即先向上计数再向下计数。
2)在该定时器上选择2个通道,并分别配置为输出比较模式,并配置在比较成功时翻转对应的引脚输出。
3)配置自动重装载寄存器TIMx_ARR为要求输出频率的一半。
4)假定CC1为第一个输出信号的通道,再假定第一个信号的正脉冲宽度对应为W1,则配置TIMx_CCR1为TIMx_ARR-W1/2。
5) 同4),假定CC2为第二个输出信号的通道,正脉冲宽度对应为W2,配置TIMx_CCR2为W2/2。
下面以一个例子说明:
假设要求输出的信号频率为10kHz,占空比为1:3。
再假设定时器的输入时钟为72MHz。
输出信号的频率10kHz,换算为计数器的数值为7200。
按照上述3),设置TIMx_ARR=3600
输出信号1的高电平时间W1,换算为计数器的数值为W1=7200/4=1800
按照上述4),设置TIMx_CC1=3600 - W1/2=2700
输出信号2的高电平时间W2,换算为计数器的数值为W2=7200/4=1800
按照上述5),设置TIMx_CC2=2/2=450
参照下图,图中红线表示计数器的数值变化:
①当计数器的数值从0向上计数,达到TIMx_CC1时,CC1匹配成功,CC1的输出电平翻转;
②计数器继续向上计数,达到TIMx_ARR时开始调头向下计数;当计数器的数值下降到TIMx_CC1时,CC1再次匹配成功,CC1的输出电平再次翻转;
③计数器继续向下计数,达到到TIMx_CC2时,CC2匹配成功,CC2的输出电平翻转;
④计数器继续向下计数,减到0时开始调头向上计数;当计数器的数值上升到TIMx_CC2时,CC2再次匹配成功,CC2的输出电平再次翻转;
如此循环,得到连续的相位互为180度的两路输出波形。
注意:上述描述是一个原理性的说明,但能够输出要求的波形并且占空比可调,实际编程计算中需要可能需要对某些数值加1或者减1,以达到准确地输出。
评分
参与人数 1威望 +5 收起 理由
kk5290122 + 5 很给力!
查看全部评分
lxyppc 发表于 2009-12-28 17:08 | 显示全部楼层
“中间对齐计数”,这个方法很妙
香水城 发表于 2009-12-28 17:35 | 显示全部楼层
再来一个占空比大于50%的示意图:
香水城 发表于 2009-12-28 17:54 | 显示全部楼层
哈哈,16楼强人,手好快!!
俺也觉得Toggle模式不是很好,因为没有写程序具体测试,所以也没有细究,:$
lxyppc 发表于 2009-12-28 18:01 | 显示全部楼层
呵呵,“中间对齐模式”真的是一语点醒梦中人。
楼主的这个问题我也在想单普通Timer的解决方法,看到你给了个这么好的思路所以忍不住就写了
评分
参与人数 1威望 +1 收起 理由
junsi + 1
查看全部评分
 楼主| junsi 发表于 2009-12-28 21:16 | 显示全部楼层
感谢楼上两位,对你们的热心及专业深表佩服!在下受益匪浅
clock_lin 发表于 2010-2-2 16:25 | 显示全部楼层
真不错!
