东芝的TLP250 看看是否可以
听说可以达到1个安培
TOSHIBA Photocoupler GaAlAs Ired & Photo−IC
TLP250
Transistor Inverter
Inverter For Air Conditionor
IGBT Gate Drive
Power MOS FET Gate Drive
The TOSHIBA TLP250 consists of a GaAlAs light emitting diode and a
integrated photodetector.
This unit is 8−lead DIP package.
TLP250 is suitable for gate driving circuit of IGBT or power MOS FET.
• Input threshold current: IF=5mA(max.)
• Supply current (ICC): 11mA(max.)
• Supply voltage (VCC): 10−35V
• Output current (IO): ±1.5A (max.)
• Switching time (tpLH/tpHL): 1.5μs(max.)
• Isolation voltage: 2500Vrms(min.)
• UL recognized: UL1577, file No.E67349
• Option (D4) type
VDE approved: DIN VDE0884/06.92,certificate No.76823
Maximum operating insulation voltage: 630VPK
Highest permissible over voltage: 4000VPK
(Note) When a VDE0884 approved type is needed,
please designate the "option (D4)"
