| 今天读到一篇论文里说,零电压开关ZVS是桥式拓扑里很合适的软开关技术,它能让MOSFET的体二级管得到应用,而不用并接快速恢复二极管。 对这个说法不是很理解,文中使用的是移向全桥, 具体参数为10 kW,500 kHz Phase-ShiftControlled Series-Resonant Inverter
 原文的说法:This paper describes the design and implementationof a
 10 kW,500 lrHz PSC-SRT.The power level and high switching frequency leaves MOSFETs as the only present alternative for the switches'implementation.Also,soft switching is required to achieve efficient and reliable operation of the inverter.
 It has been shown that zero-voltage-switching(ZVS)is the preferred soft switching technique for MOSFETs in a bridge topology because it allows the use of the MOSFETs'internal body diodes sinceno fast recovery diodes are required.
 请各位高手给予指点。
