PCI Development Kit, Cyclone II Edition
2776|0
 楼主| jameswangchip 发表于 2009-12-29 10:06 | 显示全部楼层 |阅读模式
Altera's PCI Development Kit, Cyclone® II Edition provides a flexible, low-cost FPGA development platform in a PCI short card form factor. With a universal (3.3-V and 5-V) PCI edge connector, the PCI Development Kit, Cyclone II Edition plugs into any standard PCI or PCI-X slot. The kit includes both a hardware reference design and Windows software drivers to accelerate development. Users can perform transactions between the PCI interface and DDR2 memory within minutes of opening the box. The kit can be used as a development platform for 32-bit and 64-bit PCI, PCI-X, DDR2 SDRAM, and Altera Megafunction Partners Program (AMPPSM) partner intellectual property (IP) cores.
Development Kit ContentsThe PCI Development Kit, Cyclone II Edition features:
  • Cyclone II PCI Development Board (see Figure 1)
    • Cyclone II EP2C35F672 FPGA
    • Short-form universal PCI (3.3 or 5.0 V) card
      • 32-bit or 64-bit PCI per the PCI Local Bus Specification Revision 2.3 at 33 or 66 MHz
      • 100 MHz PCI-X Revision 2.0 mode 1
    • Memory
      • Two 64 Mbyte DDR2 SDRAM devices
    • FPGA device configuration
      • Switch-selectable on power-up, choose one of two serial configuration devices (EPCS64 devices). One device contains the pre-loaded factory default design, and the other device is for user-programming. Configuration data is downloaded via the USB-Blaster™ download cable.
    • Flexible clocking options
      • Socketed 100-MHz high-speed clock oscillator
      • SMA connector clock input
      • PCI edge connector clock input
    • Switches and indicators
      • Four user-definable push-button switches
      • Eight-position user-definable dual in-line package (DIP) switch
      • Eight user-definable LEDs
    • Flexible power options
      • PCI connector
      • External power supply
  • PCI Development Kit, Cyclone II Edition CD-ROM
    • PCI-to-DDR2 Reference Design
    • Cyclone II PCI Development Kit Application & Drivers
  • PLD Applications PCI-X CORE CD-ROM
    • PLD Applications PCI-X function for OpenCore® evaluation
    • Reference designs&applications targeted to the Cyclone II PCI development board
  • Quartus® II design software, including the SOPC Builder system development tool
    • One-year license
    • Windows platform only
  • Jungo WinDriver Development Toolkit
  • Cables&accessories
    • USB Blaster download cable
    • Power cable
  • Complete documentation
Figure 1. Cyclone II PCI Development Board
Software Development ToolsThe Quartus II design software allows designers to process multi-million-gate designs, streamline development flows, and decrease time-to-market. The PCI Development Kit, Cyclone II Edition includes the Quartus II design software with a one-year license. Altera recommends that designers purchase a full Altera® design software subscription.
The kit also includes the MegaCore® IP Library CD containing all released Altera intellectual property (IP) MegaCore functions, optimized for Altera devices, including:
  • PCI Compiler 32-Bit PCI Master/Target
  • PCI Compiler 32-Bit PCI Target
  • PCI Compiler 64-Bit Master/Target
  • PCI Compiler 64-Bit Target
  • DDR&DDR2 SDRAM Memory Controller Compiler
Hardware Development ToolsThe PCI Development Kit, Cyclone II Edition includes VHDL and Verilog reference designs, example projects, and complete documentation.
销售价格 RMB 9950.000
北京蓝景世纪公司
地址:北京市海淀区知春路128号泛亚大厦1892B
邮编: 100086
电话:010-82626934,82627105
传真:010-51664726
联系人: 李先生( RICHIE LEE)
Http://www.bluechipsemi.com
个人签名:新浪微博:阿牛哥在北京 http://www.weibo.com/brotherbull QQ:1047177125
2865
