STM32 CRC32计算结果与软件算的不同
13454|19
 楼主| 梅川酷子 发表于 2010-1-3 12:45 | 显示全部楼层 |阅读模式
uc32 crc32_table[256] =
0x00000000, 0x04c11db7, 0x09823b6e, 0x0d4326d9, 0x130476dc, 0x17c56b6b,
0x1a864db2, 0x1e475005, 0x2608edb8, 0x22c9f00f, 0x2f8ad6d6, 0x2b4bcb61,
0x350c9b64, 0x31cd86d3, 0x3c8ea00a, 0x384fbdbd, 0x4c11db70, 0x48d0c6c7,
0x4593e01e, 0x4152fda9, 0x5f15adac, 0x5bd4b01b, 0x569796c2, 0x52568b75,
0x6a1936c8, 0x6ed82b7f, 0x639b0da6, 0x675a1011, 0x791d4014, 0x7ddc5da3,
0x709f7b7a, 0x745e66cd, 0x9823b6e0, 0x9ce2ab57, 0x91a18d8e, 0x95609039,
0x8b27c03c, 0x8fe6dd8b, 0x82a5fb52, 0x8664e6e5, 0xbe2b5b58, 0xbaea46ef,
0xb7a96036, 0xb3687d81, 0xad2f2d84, 0xa9ee3033, 0xa4ad16ea, 0xa06c0b5d,
0xd4326d90, 0xd0f37027, 0xddb056fe, 0xd9714b49, 0xc7361b4c, 0xc3f706fb,
0xceb42022, 0xca753d95, 0xf23a8028, 0xf6fb9d9f, 0xfbb8bb46, 0xff79a6f1,
0xe13ef6f4, 0xe5ffeb43, 0xe8bccd9a, 0xec7dd02d, 0x34867077, 0x30476dc0,
0x3d044b19, 0x39c556ae, 0x278206ab, 0x23431b1c, 0x2e003dc5, 0x2ac12072,
0x128e9dcf, 0x164f8078, 0x1b0ca6a1, 0x1fcdbb16, 0x018aeb13, 0x054bf6a4,
0x0808d07d, 0x0cc9cdca, 0x7897ab07, 0x7c56b6b0, 0x71159069, 0x75d48dde,
0x6b93dddb, 0x6f52c06c, 0x6211e6b5, 0x66d0fb02, 0x5e9f46bf, 0x5a5e5b08,
0x571d7dd1, 0x53dc6066, 0x4d9b3063, 0x495a2dd4, 0x44190b0d, 0x40d816ba,
0xaca5c697, 0xa864db20, 0xa527fdf9, 0xa1e6e04e, 0xbfa1b04b, 0xbb60adfc,
0xb6238b25, 0xb2e29692, 0x8aad2b2f, 0x8e6c3698, 0x832f1041, 0x87ee0df6,
0x99a95df3, 0x9d684044, 0x902b669d, 0x94ea7b2a, 0xe0b41de7, 0xe4750050,
0xe9362689, 0xedf73b3e, 0xf3b06b3b, 0xf771768c, 0xfa325055, 0xfef34de2,
0xc6bcf05f, 0xc27dede8, 0xcf3ecb31, 0xcbffd686, 0xd5b88683, 0xd1799b34,
0xdc3abded, 0xd8fba05a, 0x690ce0ee, 0x6dcdfd59, 0x608edb80, 0x644fc637,
0x7a089632, 0x7ec98b85, 0x738aad5c, 0x774bb0eb, 0x4f040d56, 0x4bc510e1,
0x46863638, 0x42472b8f, 0x5c007b8a, 0x58c1663d, 0x558240e4, 0x51435d53,
0x251d3b9e, 0x21dc2629, 0x2c9f00f0, 0x285e1d47, 0x36194d42, 0x32d850f5,
0x3f9b762c, 0x3b5a6b9b, 0x0315d626, 0x07d4cb91, 0x0a97ed48, 0x0e56f0ff,
0x1011a0fa, 0x14d0bd4d, 0x19939b94, 0x1d528623, 0xf12f560e, 0xf5ee4bb9,
0xf8ad6d60, 0xfc6c70d7, 0xe22b20d2, 0xe6ea3d65, 0xeba91bbc, 0xef68060b,
0xd727bbb6, 0xd3e6a601, 0xdea580d8, 0xda649d6f, 0xc423cd6a, 0xc0e2d0dd,
0xcda1f604, 0xc960ebb3, 0xbd3e8d7e, 0xb9ff90c9, 0xb4bcb610, 0xb07daba7,
0xae3afba2, 0xaafbe615, 0xa7b8c0cc, 0xa379dd7b, 0x9b3660c6, 0x9ff77d71,
0x92b45ba8, 0x9675461f, 0x8832161a, 0x8cf30bad, 0x81b02d74, 0x857130c3,
0x5d8a9099, 0x594b8d2e, 0x5408abf7, 0x50c9b640, 0x4e8ee645, 0x4a4ffbf2,
0x470cdd2b, 0x43cdc09c, 0x7b827d21, 0x7f436096, 0x7200464f, 0x76c15bf8,
0x68860bfd, 0x6c47164a, 0x61043093, 0x65c52d24, 0x119b4be9, 0x155a565e,
0x18197087, 0x1cd86d30, 0x029f3d35, 0x065e2082, 0x0b1d065b, 0x0fdc1bec,
0x3793a651, 0x3352bbe6, 0x3e119d3f, 0x3ad08088, 0x2497d08d, 0x2056cd3a,
0x2d15ebe3, 0x29d4f654, 0xc5a92679, 0xc1683bce, 0xcc2b1d17, 0xc8ea00a0,
0xd6ad50a5, 0xd26c4d12, 0xdf2f6bcb, 0xdbee767c, 0xe3a1cbc1, 0xe760d676,
0xea23f0af, 0xeee2ed18, 0xf0a5bd1d, 0xf464a0aa, 0xf9278673, 0xfde69bc4,
0x89b8fd09, 0x8d79e0be, 0x803ac667, 0x84fbdbd0, 0x9abc8bd5, 0x9e7d9662,
0x933eb0bb, 0x97ffad0c, 0xafb010b1, 0xab710d06, 0xa6322bdf, 0xa2f33668,
0xbcb4666d, 0xb8757bda, 0xb5365d03, 0xb1f740b4
u32 GetCRC32(u32 crc32, u8 *p, u32 len)
while (len--)
  crc32 = crc32_table[(crc32 >> 24) ^  *p++] ^ (crc32 << 8);
return crc32;
extern uint32_t __RBIT(uint32_t value);
void STM32_CRC32Test(void)
u8  *PtrByte;
u32 *PtrWord;
u32 idx,HwCRC32,SwCRC32;
PtrByte=(u8 *)CRC32_TABLE;
PtrWord=(u32 *)CRC32_TABLE;
  SwCRC32 = GetCRC32(0, PtrByte, sizeof(CRC32_TABLE));
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_CRC, ENABLE);
CRC_ResetDR();
for(idx = 0; idx < (sizeof(CRC32_TABLE)/4); idx++)
   CRC->DR =__RBIT(PtrWord[idx]);
HwCRC32=__RBIT(CRC->DR);
HwCRC32^=0xffffffffUL;
上面程序运行结果是:
HwCRC32=0x33EE8D5B
SwCRC32=0x36368B8B
请问这个CRC32算法如何转换成STM32内置的CRC32模块进行运算呢?
我按照网上资料说,把32位数据进行倒序,结果再再倒序,再与0XFFFFFFFF进行异或
但结果还是不对,问题出来哪呢?
aresc 发表于 2010-1-3 17:19 | 显示全部楼层
有几个疑问:
1. 你的硬件结果和软件结果哪一个是对的?会不会都不对?
2. 代码里crc32_table定义的是uc32类型,有没有需要特别注意的地方?
3. 用u8 *去寻址u32 的CRC32_TABLE,比如0x12345678,是先寻到0x78,还是0x12?
4. 另外要注意的是sizeof(CRC32_TABLE)是以字节计算的长度。
总之你要先确定哪一个结果是对的,然后再去查那个不对的;如果硬件不对,那肯定你没弄对硬件的设置,要仔细看手册;如果是软件不对,那就把语句尽量拆分成简单的语句,去看哪一步出错了,当然你也要弄明白crc32的算法。
另外,最好把裤子穿上,呵呵...
香水城 发表于 2010-1-3 18:00 | 显示全部楼层
请看看这个帖子以及相关的讨论吧:STM32内置CRC模块的使用
zwll 发表于 2010-1-3 20:49 | 显示全部楼层
香主的精华啊,温习温习
司徒老鹰 发表于 2010-1-3 20:59 | 显示全部楼层
北京下好大学啊,楼主不穿裤子不冷,呵呵
 楼主| 梅川酷子 发表于 2010-1-4 22:09 | 显示全部楼层
多谢各位,好像没有看到STM32的CRC32讨论结果?
PS:我这个CRC32程序是IAR网站上面找来的,
lxyppc 发表于 2010-1-4 22:42 | 显示全部楼层
我这里也有个能用的
结果就是有人认为STM32的是非主流,其实这东西没有所谓的主流与非主流
///  CRC32 Calculator for STM32
///  Author:   lxyppc
///  E-Mail:   lxyppc@163.com
///  Version:  1.0
///  Data:     2009-04-13
///  This program is based on STOne-32's
///  http://www.st.com/mcu/forums-cat-7171-23.html
///  Example:
///  CRC_ResetDR();
///  ASSERT(CrcGen_STM32(data,size) == CRC_CalcBlockCRC(data,size));
unsigned long CrcGen_STM32(unsigned long data[], unsigned long size)
    unsigned long crc = 0xFFFFFFFF;
    for(unsigned long i=0;i<size;i++){
        unsigned long temp = data;
        for(unsigned long j=0;j<32;j++){
            if( (crc ^ temp) & 0x80000000 ){
                crc = 0x04C11DB7 ^ (crc<<1);
            }else{
                crc <<=1;
            temp<<=1;
    return crc;
 楼主| 梅川酷子 发表于 2010-1-5 00:12 | 显示全部楼层
while (len--)
return crc32;
SwCRC32 = GetCRC32(0xffffffffUL,Ptr,Length);
特价于:
Length>>=2;
CRC->DR=0xffffffffUL;
while(Length--)
    CRC->DR =__REV(*Ptr++);    //字节顺序倒过来,注意不是位序,不是用__RBIT指令
HwCRC32=CRC->DR;
搞定!!!!
 楼主| 梅川酷子 发表于 2010-1-5 00:15 | 显示全部楼层
上面那个应该是SwCRC32 = GetCRC32(0,Ptr,Length);
yybj 发表于 2010-1-5 10:15 | 显示全部楼层
可能是你定义的数据类型不对吧,会溢出
 楼主| 梅川酷子 发表于 2010-1-5 12:38 | 显示全部楼层
溢出?啥?
xsgy123 发表于 2010-1-5 15:54 | 显示全部楼层
楼主搞定了?问题在哪
sinadz 发表于 2010-1-5 16:23 | 显示全部楼层
6楼的链接不错,楼主可以试试
 楼主| 梅川酷子 发表于 2010-1-5 16:31 | 显示全部楼层
hotpower 发表于 2011-6-22 23:26 | 显示全部楼层
dolido 发表于 2011-6-23 13:24 | 显示全部楼层
很受教呀
jioa 发表于 2011-6-23 14:38 | 显示全部楼层
梅川的链接打不开呢
咋回事呢
yinhaix 发表于 2015-5-25 16:02 | 显示全部楼层
周董 发表于 2015-5-25 20:31 | 显示全部楼层
取模软件看上去很强大呀
