Question
2549|4
 楼主| ChanTaiMan 发表于 2010-1-18 09:48 | 显示全部楼层 |阅读模式
Hi Everyone,
I am looking for a CPU which should fulfill the following requirements:-
-Not BGA footprint.
-About 100MHz.
-With External Memory Interface (EMI).
-With EXternal SDRAM interface.
-With built-in SPI controller, both Mater & Slave.
-With USB Device.
-UARTx2
-PWMx1
-With internal Fireware-Flash.
Any suggestions.
Thank you
ChanTaiMan
mohanwei 发表于 2010-1-19 19:39 | 显示全部楼层
must have SDRAM interface?
AT91SAM9260
NE5532 发表于 2010-1-19 21:36 | 显示全部楼层
Try NXP's ARM: LPC2388
原野之狼 发表于 2010-1-20 10:34 | 显示全部楼层
还有国外友人逛21IC呢
酱油店老板 发表于 2010-1-20 10:46 | 显示全部楼层
哇,还03注册的。
