| 141.4 x 109.5 mm (expansion board)
67.6 x 47 mm (CPU board) |
| Atmel AT91SAM9261S (ARM926EJ-S core,Capable of 200MHz operation, AT91SAM9261 is compatible) |
| 64MB SDRAM
256MB NandFlash (bootable, selected through jumper)
4MB SPI Serial DataFlash (bootable, selected through jumper)
8MB NorFlash
1Kbit EEPROM (DS2431) |
| 1 x 9-wire RS232 serial port
1 x 5-wire RS232/TTL serial port
1 x 3-wire RS232/TTL serial port (Debug unit)
1 x RS485 serial port or one 3-wire TTL serial port |
| 1 x 10/100Mbps Ethernet port (RJ45) |
| 2 x USB2.0 Host and 1 x USB Device |
| 1 x 40-pin LCD display interface (TFT)
(Supporting resolution up to 2048×2048) |
| Standard VGA display port (CH7026) |
| with a rechargeable battery |
| 4 x buttons (one for Wakeup, one for Reset) |
| 1 x Mic jack
1 x Phone jack |
| 20-pin standard JTAG slot |
| 1 x SPI interface (multiplex with CAN interface) |
Linux2.6.24 (source code) , ramdisk, yaffs2 file-system |
