目的:想用外部中断测试CAN实现自发自收。首先点亮全部的LED灯,按下键一以CAN_Polling收发数据,如果成功则熄灭一个LED灯,否则熄灭相邻的一个LED灯。按下键2以CAN_Interrupt收发数据,如果成功则熄灭一个LED灯。否则熄灭相邻的一个LED灯。但是实验总不成功。刚学这个,还请大家指点一下
主程序:
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration();
GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_Pin_3 | GPIO_Pin_4);
EXTI_InitStructure.EXTI_Line = EXTI_Line3 | EXTI_Line4;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
EXTI_GenerateSWInterrupt(EXTI_Line3 | EXTI_Line4);
/*循环点亮LED1-LED4*/
while (1)
GPIO_SetBits(GPIOC, GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7);
中断程序:
void EXTI3_IRQHandler(void)
while (EXTI_GetITStatus(EXTI_Line3) != RESET)
TestRx = CAN_Polling();
if (TestRx == FAILED)
GPIO_ResetBits(GPIOC, GPIO_Pin_4);
else
GPIO_ResetBits(GPIOC, GPIO_Pin_5);
EXTI_ClearITPendingBit(EXTI_Line3);
void EXTI4_IRQHandler(void)
while (EXTI_GetITStatus(EXTI_Line4) != RESET)
TestRx = CAN_Interrupt();
GPIO_ResetBits(GPIOC, GPIO_Pin_6);
else
GPIO_ResetBits(GPIOC, GPIO_Pin_7);
EXTI_ClearITPendingBit(EXTI_Line4);
