[PIC®/AVR®/dsPIC®产品] PIC18F编程目标不匹配
1292|1
 楼主| xxlnbzj 发表于 2016-5-10 16:15 | 显示全部楼层 |阅读模式
芯片为PIC18F23K20
检查过连线,ICD3也是好用的,测试板也换过三块,的出现下面的错误
Connecting to MPLAB ICD 3...
Currently loaded firmware on ICD 3
Firmware Suite Version.....01.38.10
Firmware type..............PIC18F
Target voltage detected
Target Device ID (0x0) does not match expected Device ID (0x20e0).
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x17f
configuration memory
Device Erased...
Programming...
program memory
Address: 0 Expected Value: 51 Received Value: 0
Failed to program device
用IPE可以查擦除程序
下载的时候出现错误
编程中...
程序存储器
地址:0  期望数值:51  收到数值:0
编程器件失败
2016-05-10T15:55:52+0800- Programming failed
Pass Count: 1
JY-DX-JY 发表于 2016-5-11 09:40 | 显示全部楼层
断电、重插、重启
