请帮我看看什么地方有问题?
2461|0
 楼主| fang2001 发表于 2010-3-1 16:51 | 显示全部楼层 |阅读模式
void Init_ADC(void)
  //初始化IO口
  AD1CR_bit.SEL = 6;      //enable AD1.6
  AD1CR_bit.CLKDIV = 60000000/4500000;
  AD1CR_bit.BURST = 0;    // put A/D into continuous convert mode
  AD1CR_bit.CLKS = 0;     //11 clocks/10 bit accuracy
  AD1CR_bit.PDN = 1;      //power up the unit
  PINSEL1_bit.P0_21 = 2;  // This is probably the potentiometer output
  //开始转换
  AD1CR_bit.START = 0x0001;                     //start 1st cnvrsn immediately
//读取ADC的值
unsigned int Read_ADC(void)
  unsigned int ADCresult;
  while(AD1DR6_bit.DONE == 0);                //wait until conversion done
  ADCresult = AD1DR6_bit.VVDDA ;              // save the converted data
  //开始下一次转换
  AD1CR_bit.START = 0x0001;                  // start the next conversion
  return ADCresult;
请那位告诉帮我看看。什么地方有问题呀。例程改的。谢谢
