[i.MX] imx编译问题
1393|1
 楼主| wince_lover 发表于 2016-5-12 14:53 | 显示全部楼层 |阅读模式
我下载的是4.1.15的BSP.编译命令是
MACHINE=imx6qsabresd DISTRO=fsl-imx-x11 source ./fsl-setup-release.sh -b imx6q-x11
bitbake fsl-image-qt5
编译的时候出现了下面的错误
ERROR: Fetcher failure: Fetch command failed with exit code 4, output:
wget: unable to resolve host address 'www_freescale_com'
ERROR: Function failed: Fetcher failure for U_R_L: 'h_t_t_p_:_/_/www_freescale_com/lgfiles/NMG/MAD/YOCTO//imx-parser-4.0.9.bin;fsl-eula=true'. Unable to fetch U_R_L from any source.
ERROR: Logfile of failure stored in: /home/lisen/fsl-release-bsp/L4.1.15/imx6q-x11/tmp/work/imx6qsabresd-poky-linux-gnueabi/imx-parser/4.0.9-r0/temp/log.do_fetch.3341
ERROR: Task 3647 (/home/lisen/fsl-release-bsp/L4.1.15/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/imx-parser/imx-parser_4.0.9.bb, do_fetch) failed with exit code '1'
请fsl的工程师看看如何解决,尽快回复下.
mini1986 发表于 2016-11-10 15:52 | 显示全部楼层
h_t_t_p_:_/_/www_freescale_com,这个路径的问题吧......
