[STM32F0] 串口没有输出,
1635|7
 楼主| clz918 发表于 2016-5-13 18:18 | 显示全部楼层 |阅读模式
要崩溃了,串口没有输出,这是我找的例程,测试没有问题
  int main(void)
  //bsp_int();
  //read_dip_set();
                #define GPIO_AF_USART1 GPIO_AF_1
                  GPIO_InitTypeDef PORT_UART1_TX;
    GPIO_InitTypeDef PORT_UART1_RX;
    USART_InitTypeDef MyUsart1;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
    //??IO???????
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    //TX IO ???
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    //RX IO ???
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    //4???????
    MyUsart1.USART_BaudRate=9600;//?????
    MyUsart1.USART_WordLength=USART_WordLength_8b;//??????
    MyUsart1.USART_Parity=USART_Parity_No;//??????
    MyUsart1.USART_StopBits=USART_StopBits_1;//?????
    MyUsart1.USART_HardwareFlowControl=USART_HardwareFlowControl_None;//?????
    MyUsart1.USART_Mode=USART_Mode_Tx|USART_Mode_Rx;//????
    USART_Init(USART1,&MyUsart1);
    USART_Cmd(USART1,ENABLE);
        while(1)
        {        led1_clr;
                       USART_SendData(USART1,0x55);
                       led1_set;
                            clz++;
                       delay1ms(10);
我把IO改为PA2,PA3,  txd没有输出,一直是高,我用的是STM32F030C8T6,  怎么回事,  救命啊
  int main(void)
  //bsp_int();
  //read_dip_set();
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_USART1);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_USART1);
    //??IO???????
    //TX IO ???
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    //RX IO ???
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
    //4???????
        while(1)
        {        led1_clr;
                       led1_set;
                            clz++;
                       delay1ms(10);
forgot 发表于 2016-5-13 19:30 | 显示全部楼层
一行注释都没有。。。。。。。。
 楼主| clz918 发表于 2016-5-14 08:28 | 显示全部楼层
有用过PA2,3的吗
yklstudent 发表于 2016-5-14 09:50 | 显示全部楼层
你仔细看芯片手册了?
看完就知道到底是USART1还是USART2了
 楼主| clz918 发表于 2016-5-14 11:09 | 显示全部楼层
你仔细看芯片手册了?
A2A3也可以用于USART1
294479435 发表于 2016-5-14 11:36 | 显示全部楼层
你看下手册,输入输出引脚应该怎么配置,然后下一个官方的例程看看,和你的有什么差别
yklstudent 发表于 2016-5-14 12:19 | 显示全部楼层
A2A3也可以用于USART1
你确认你的芯片支持吗?
 楼主| clz918 发表于 2016-5-14 14:53 | 显示全部楼层
不研究了,改用usart2
