[牛人杂谈] M051的ADC怎么玩
1466|6
 楼主| 稳稳の幸福 发表于 2016-5-15 11:15 | 显示全部楼层 |阅读模式
ADC, AN, TE, se, ce
  * @brief Configure the analog input source of channel 7.
  * @param[in] adc Base address of ADC module.
  * @param[in] u32Source Decides the analog input source of channel 7. Valid values are:
  *                       - \ref ADC_ADCHER_PRESEL_EXT_INPUT_SIGNAL        : External analog input.
  *                       - \ref ADC_ADCHER_PRESEL_INT_BANDGAP             : Internal bandgap voltage.
  *                       - \ref ADC_ADCHER_PRESEL_INT_TEMPERATURE_SENSOR  : Output of internal temperature sensor.
  * @return None
  * @NOTE While using VBG as channel 7 source, ADC module clock must /b not exceed 300kHz.
#define ADC_CONFIG_CH7(adc, u32Source) (ADC->ADCHER = ((adc)->ADCHER & ~ADC_ADCHER_PRESEL_Msk) | (u32Source))
这个是个配置函数,而且指定了通道CH7.
因此这个是个特别的函数,可以配置为外部模拟输入,也可配置为内部参考电压,也可以输出为内部温度。
 楼主| 稳稳の幸福 发表于 2016-5-15 11:18 | 显示全部楼层
  * @brief Get conversion data of specified channel.
  * @param[in] u32ChNum ADC Channel, valid value are from 0 to 7.
  * @return  Read RSLT bit field to get conversion data.
#define ADC_GET_CONVERSION_DATA(adc, u32ChNum) (((adc)->ADDR[(u32ChNum)] & ADC_ADDR_RSLT_Msk)>>ADC_ADDR_RSLT_Pos)
这个是获取转换数据的函数,
 楼主| 稳稳の幸福 发表于 2016-5-15 11:20 | 显示全部楼层
  * @brief Power down ADC module.
  * @return None
#define ADC_POWER_DOWN(adc) ((adc)->ADCR &= ~ADC_ADCR_ADEN_Msk)
  * @brief Power on ADC module.
  * @return None
#define ADC_POWER_ON(adc) ((adc)->ADCR |= ADC_ADCR_ADEN_Msk)
同样ADC的模块还是可以关闭的,如果不适用,关闭的话更省电,低功耗必须的功能。
 楼主| 稳稳の幸福 发表于 2016-5-15 11:21 | 显示全部楼层
  1. /****************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
  4. * $Revision: 4 $
  5. * $Date: 14/01/28 11:44a $
  6. * @brief    M051 Series ADC Interface Controller Driver Sample Code
  7. *
  8. * @note
  9. * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
  10. *
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "M051Series.h"
  14. #define PLL_CLOCK       50000000
  15. /*---------------------------------------------------------------------------------------------------------*/
  16. /* Define Function Prototypes        */
  17. /*---------------------------------------------------------------------------------------------------------*/
  18. void SYS_Init(void);
  19. void UART0_Init(void);
  20. void AdcSingleModeTest(void);
  21. /*---------------------------------------------------------------------------------------------------------*/
  22. /* Define global variables and constants        */
  23. /*---------------------------------------------------------------------------------------------------------*/
  24. volatile uint32_t g_u32AdcIntFlag;
  25. void SYS_Init(void)
  26. {
  27.     /*---------------------------------------------------------------------------------------------------------*/
  28.     /* Init System Clock        */
  29.     /*---------------------------------------------------------------------------------------------------------*/
  30.     /* Enable Internal RC 22.1184MHz clock */
  31.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  32.     /* Waiting for Internal RC clock ready */
  33.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  34.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  35.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  36.     /* Enable external XTAL 12MHz clock */
  37.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  38.     /* Waiting for external XTAL clock ready */
  39.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  40.     /* Set core clock as PLL_CLOCK from PLL */
  41.     CLK_SetCoreClock(PLL_CLOCK);
  42.     /* Enable UART module clock */
  43.     CLK_EnableModuleClock(UART0_MODULE);
  44.     /* Enable ADC module clock */
  45.     CLK_EnableModuleClock(ADC_MODULE);
  46.     /* Select UART module clock source */
  47.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
  48.     /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
  49.     CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
  50.     /*---------------------------------------------------------------------------------------------------------*/
  51.     /* Init I/O Multi-function        */
  52.     /*---------------------------------------------------------------------------------------------------------*/
  53.     /* Set P3 multi-function pins for UART0 RXD and TXD */
  54.     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
  55.     SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
  56.     /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
  57.     GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);
  58.     /* Configure the P1.0 - P1.3 ADC analog input pins */
  59.     SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
  60.     SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
  61. }
  62. /*---------------------------------------------------------------------------------------------------------*/
  63. /* Init UART        */
  64. /*---------------------------------------------------------------------------------------------------------*/
  65. void UART0_Init()
  66. {
  67.     /* Reset IP */
  68.     SYS_ResetModule(UART0_RST);
  69.     /* Configure UART0 and set UART0 Baudrate */
  70.     UART_Open(UART0, 115200);
  71. }
  72. /*---------------------------------------------------------------------------------------------------------*/
  73. /* Function: AdcSingleModeTest        */
  74. /*        */
  75. /* Parameters:        */
  76. /*   None.        */
  77. /*        */
  78. /* Returns:        */
  79. /*   None.        */
  80. /*        */
  81. /* Description:        */
  82. /*   ADC single mode test.        */
  83. /*---------------------------------------------------------------------------------------------------------*/
  84. void AdcSingleModeTest()
  85. {
  86.     uint8_t  u8Option;
  87.     int32_t  i32ConversionData;
  88.     printf("\n");
  89.     printf("+----------------------------------------------------------------------+\n");
  90.     printf("|                      ADC single mode sample code                     |\n");
  91.     printf("+----------------------------------------------------------------------+\n");
  92.     while(1)
  93.     {
  94.         printf("Select input mode:\n");
  95.         printf("  [1] Single end input (channel 2 only)\n");
  96.         printf("  [2] Differential input (channel pair 1 only)\n");
  97.         printf("  Other keys: exit single mode test\n");
  98.         u8Option = getchar();
  99.         if(u8Option == '1')
  100.         {
  101.             /* Set the ADC operation mode as single, input mode as single-end and enable the analog input channel 2 */
  102.             ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE, 0x1 << 2);
  103.             /* Power on ADC module */
  104.             ADC_POWER_ON(ADC);
  105.             /* clear the A/D interrupt flag for safe */
  106.             ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  107.             /* Enable the ADC interrupt */
  108.             ADC_EnableInt(ADC, ADC_ADF_INT);
  109.             NVIC_EnableIRQ(ADC_IRQn);
  110.             /* Reset the ADC interrupt indicator and Start A/D conversion */
  111.             g_u32AdcIntFlag = 0;
  112.             ADC_START_CONV(ADC);
  113.             /* Wait ADC interrupt (g_u32AdcIntFlag will be set at IRQ_Handler function)*/
  114.             while(g_u32AdcIntFlag == 0);
  115.             /* Disable the ADC interrupt */
  116.             ADC_DisableInt(ADC, ADC_ADF_INT);
  117.             /* Get the conversion result of the ADC channel 2 */
  118.             i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 2);
  119.             printf("Conversion result of channel 2: 0x%X (%d)\n\n", i32ConversionData, i32ConversionData);
  120.         }
  121.         else if(u8Option == '2')
  122.         {
  123.             /* Set the ADC operation mode as single, input mode as differential and
  124.                enable analog input channel 2 for differential input channel pair 1*/
  125.             ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_SINGLE, 0x1 << 2);
  126.             /* Power on ADC module */
  127.             ADC_POWER_ON(ADC);
  128.             /* clear the A/D interrupt flag for safe */
  129.             ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  130.             /* Enable the ADC interrupt */
  131.             ADC_EnableInt(ADC, ADC_ADF_INT);
  132.             NVIC_EnableIRQ(ADC_IRQn);
  133.             /* Reset the ADC interrupt indicator and Start A/D conversion */
  134.             g_u32AdcIntFlag = 0;
  135.             ADC_START_CONV(ADC);
  136.             /* Wait ADC interrupt (g_u32AdcIntFlag will be set at IRQ_Handler function)*/
  137.             while(g_u32AdcIntFlag == 0);
  138.             /* Disable the ADC interrupt */
  139.             ADC_DisableInt(ADC, ADC_ADF_INT);
  140.             /* Get the conversion result of the specified ADC channel */
  141.             i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 2);
  142.             printf("Conversion result of channel pair 1: 0x%X (%d)\n\n", i32ConversionData, i32ConversionData);
  143.         }
  144.         else
  145.             return ;
  146.     }
  147. }
  148. /*---------------------------------------------------------------------------------------------------------*/
  149. /* ADC interrupt handler        */
  150. /*---------------------------------------------------------------------------------------------------------*/
  151. void ADC_IRQHandler(void)
  152. {
  153.     g_u32AdcIntFlag = 1;
  154.     ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT); /* clear the A/D conversion flag */
  155. }
  156. /*---------------------------------------------------------------------------------------------------------*/
  157. /* MAIN function        */
  158. /*---------------------------------------------------------------------------------------------------------*/
  159. main(void)
  160. {
  161.     /* Unlock protected registers */
  162.     SYS_UnlockReg();
  163.     /* Init System, IP clock and multi-function I/O */
  164.     SYS_Init();
  165.     /* Lock protected registers */
  166.     SYS_LockReg();
  167.     /* Init UART0 for printf */
  168.     UART0_Init();
  169.     /*---------------------------------------------------------------------------------------------------------*/
  170.     /* SAMPLE CODE        */
  171.     /*---------------------------------------------------------------------------------------------------------*/
  172.     printf("\nSystem clock rate: %d Hz", SystemCoreClock);
  173.     /* Single Mode test */
  174.     AdcSingleModeTest();
  175.     /* Disable ADC module */
  176.     ADC_Close(ADC);
  177.     /* Disable ADC IP clock */
  178.     CLK_DisableModuleClock(ADC_MODULE);
  179.     /* Disable External Interrupt */
  180.     NVIC_DisableIRQ(ADC_IRQn);
  181.     printf("\nExit ADC sample code\n");
  182.     while(1);
  183. }
我们来个看个例程。
 楼主| 稳稳の幸福 发表于 2016-5-15 11:26 | 显示全部楼层
单次采样的初始化方式
 楼主| 稳稳の幸福 发表于 2016-5-15 11:28 | 显示全部楼层
ADC有3种工作模式:单次、单次循环和连续循环模式。
²  单次:就是在某个使能的通道上完成一次转换就停止
²  单次循环:就是在所有使能的通道上完成一次转换就停止
²  连续循环:就是在所有使能的通道完成一次转换,再完成一次转换,连续不断的转换,直到软件将其停止
ADC的信号有2种输入模式:单端,差分
²  单端:就是采样单个通道
²  差分:就是两个通道的信号相减再采样
上面的代码选择HIRC做ADC的时钟源,并且进行除频,也就是ADC的工作频率为12M/5 = 2.4M。然后使能ADC的时钟,将PA.0配置为ADC功能,同时关闭PA.0的数字通路。最后配置ADC 为单端,单次模式,并使能通道0,选择Vref引脚作参考源,并使能ADC中断。启动ADC转换,等转换完成之后,读取转换结果。
 楼主| 稳稳の幸福 发表于 2016-5-15 11:29 | 显示全部楼层
要让ADC工作很容易,但是要用好ADC是不容易的。ADC的转换结果受参考电压的影响很大,如果希望转换结果更准确,参考电压就不能波动。另外如果使能了多个通道轮流采样,因为内部只有一个采样电容,各个通道之间会互相影响。这个时候可以通过外加电容,并降低ADC的工作频率,增加ADC的采样时钟等办法来解决。
例如:使用ADC检测VDD电压。使用两个400K电阻分压然后拉到PA.0采样,同时PA.1也使能用来采样其它的信号。这时候如果PA.1的电压比PA.0高,检测到的VDD电压会偏高,否则会偏低。用示波器看PA.0的信号,也会看到信号是波动的,这个波动很正常。因为PA.1比PA.0高的时候,采样PA.0时,内部采样电容会放电,将PA.0的电压拉高。这时候降低ADC的工作频率,增加采样时钟个数,测到的PA.0的值就会正常了。如果PA.1比PA.0低,这时候PA.0外部需要接对地电容,它可以对PA.0快速充电,测到的PA.0的值就会正常了。
所以,
1)      外加电容
2)      降低 ADC 工作频率
3) 增加 ADC 采样时钟是调ADC精度常用的手段。
