[51单片机] 为什么在实验板上显示明显大于1s呢?
700|1
 楼主| sunny鱼儿 发表于 2016-5-15 19:10 | 显示全部楼层 |阅读模式
#include<reg52.h>
sbit HC595_RCK=P1^0;
sbit HC595_SCK=P1^1;
sbit HC595_DATA=P1^4;
code unsigned char Shu_One_Array[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
code unsigned char Shu_Two_Array[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
void Shu_DATA(unsigned char Shu_Data_One,unsigned char Shu_Data_Two)
{  unsigned char i;
   HC595_RCK=0;
   for(i=0;i<8;i++)
            HC595_SCK=0;
        if(0==(Shu_Data_One&0x80))
                   HC595_DATA=0;
          else
                   HC595_DATA=1;
          HC595_SCK=1;
          Shu_Data_One=Shu_Data_One<<1;
   for(i=0;i<8;i++)
            HC595_SCK=0;
        if(0==(Shu_Data_Two&0x80))
                   HC595_DATA=0;
          else
                   HC595_DATA=1;
          HC595_SCK=1;
          Shu_Data_Two=Shu_Data_Two<<1;
    HC595_RCK=1;
void delay_1ms(int i)
   int j;
   for(;i>0;i--)
    for(j=0;j<110;j++);
void Time0_Init()
    TMOD|=0X01;
        TH0=0xdc;
        TL0=0x00;
        TR0=1;
void main()
  unsigned char m=0,j=0,k=0,Counter=0;
  Time0_Init();
   while(1)
              if(1==TF0)
                    TF0=0;
                 TH0=0xdc;
             TL0=0x00;
                 Counter++;
           if(100==Counter)
                            Counter=0;
                         k++;
                         if(k>59)
                           k=0;
                           j++;
                           if(j>59)
                                    j=0;
                                 m++;
                                 if(m>23)
                                   m=0;
                 Shu_DATA(Shu_One_Array[m/10],Shu_Two_Array[0]);
                 delay_1ms(1);
                 Shu_DATA(Shu_One_Array[m%10],Shu_Two_Array[1]);
                 delay_1ms(1);
                 Shu_DATA(0x40,Shu_Two_Array[2]);
                 delay_1ms(1);
                 Shu_DATA(Shu_One_Array[j/10],Shu_Two_Array[3]);
                 delay_1ms(1);
                 Shu_DATA(Shu_One_Array[j%10],Shu_Two_Array[4]);
                 delay_1ms(1);
                 Shu_DATA(0x40,Shu_Two_Array[5]);
                 delay_1ms(1);
                 Shu_DATA(Shu_One_Array[k/10],Shu_Two_Array[6]);
                 delay_1ms(1);
                 Shu_DATA(Shu_One_Array[k%10],Shu_Two_Array[7]);
                 delay_1ms(1);
mcu5i51 发表于 2016-5-16 16:25 | 显示全部楼层
因为你的程序不可能准呀,大于1S不是正常吗;
循环中
是否时间到,你认为到了的时候可以已经过了好久了
