[i.MX] uboot里面添加开机**
1597|2
 楼主| 867405479 发表于 2016-5-16 17:40 | 显示全部楼层 |阅读模式
显示屏接口是lvds0,之前参考了帖子参考一下帖子https://community.freescale.com/docs/DOC-98109,没有显示,我的板子是从eMMC启动的,采用mfgtools工具烧写,启动的时候一点显示都没有,这是我的mx6q_sabresd.h,// Select one of the output mode
//        #define IPU_OUTPUT_MODE_HDMI
        #define IPU_OUTPUT_MODE_LVDS
//        #define IPU_OUTPUT_MODE_LCD
#ifdef IPU_OUTPUT_MODE_LVDS
        // For LVDS, 1024*768 resolution
        #define DISPLAY_WIDTH        1366
        #define DISPLAY_HEIGHT        768
        #define DISPLAY_BPP                24
        #define DISPLAY_IF_BPP        18  // RGB666 interface
        #define DISPLAY_HSYNC_START        220
        #define DISPLAY_HSYNC_END                40
        #define DISPLAY_HSYNC_WIDTH        60
        #define DISPLAY_VSYNC_START        21
        #define DISPLAY_VSYNC_END                7
        #define DISPLAY_VSYNC_WIDTH        10
        #define DISPLAY_PIX_CLOCK        64000000
#define DISPLAY_VSYNC_POLARITY                        1
        #define DISPLAY_HSYNC_POLARITY                        1
        #define DISPLAY_CLOCK_POLARITY                        1
        #define DISPLAY_DATA_POLARITY                                0
        #define DISPLAY_DATA_ENABLE_POLARITY                1
        #define IPU_NUM                        1  // 1 for IPU1, 2 for IPU2.
        #define DI_NUM                        1  // 0 for DI0, 1 for DI1.
        #define LVDS_PORT                0  // 0 for LVDS0, 1 for LVDS1.
        #define DI_CLOCK_EXTERNAL_MODE
 楼主| 867405479 发表于 2016-5-16 17:47 | 显示全部楼层
我使用的开发板是天嵌的E9,bootloader是uboot 2009,内核版本是3.0.35,采用eMMC方式启动,求高手解答
 楼主| 867405479 发表于 2016-6-7 14:55 | 显示全部楼层
帖子,一沉到底
