汇编程序出现的地址警告和错误,如何解决?
3112|8
 楼主| cqh250551610 发表于 2010-3-3 09:19 | 显示全部楼层 |阅读模式
Error[126]   C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 379 : Argument out of range (044E not between 0000 and 03FF)
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 379 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 381 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 382 : Address exceeds maximum range for this processor.
Error[126]   C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 383 : Argument out of range (044E not between 0000 and 03FF)
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 383 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 385 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 386 : Address exceeds maximum range for this processor.
Error[126]   C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 387 : Argument out of range (044E not between 0000 and 03FF)
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 387 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 389 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 390 : Address exceeds maximum range for this processor.
Error[126]   C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 391 : Argument out of range (044E not between 0000 and 03FF)
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 391 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 394 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 395 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 399 : Address exceeds maximum range for this processor.
Error[126]   C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 400 : Argument out of range (047F not between 0000 and 03FF)
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 400 : Address exceeds maximum range for this processor.
Warning[220] C:\PROGRAM FILES\PICMATE2004\WORKS\SOUD_OUT.ASM 401 : Address exceeds maximum range for this processor
以上是编译后的输出信息。我不知问题出在哪里错了。请高手提个建议,
chen3bing 发表于 2010-3-3 09:25 | 显示全部楼层
地址超出范围,程序空间不够用了,还是体没设置好。
 楼主| cqh250551610 发表于 2010-3-3 09:33 | 显示全部楼层
程序不是很长,程序空间应该够用啊,出错的全是GOTO这个无条件跳转指令。如果是设置,那该设置哪里呢?
chen3bing 发表于 2010-3-3 09:36 | 显示全部楼层
程序贴出来。
 楼主| cqh250551610 发表于 2010-3-3 09:45 | 显示全部楼层
打包了,请下载。
chen3bing 发表于 2010-3-3 10:03 | 显示全部楼层
你的源程序有好多错误,没有END
SOUD_HEAD.INC头文件在哪个目录下?
还有个标号WAIT没有,改正后试试。
 楼主| cqh250551610 发表于 2010-3-3 11:31 | 显示全部楼层
你说的问题都有弄,我刚才试了把程序部分顺序改了,结果没有错误了,只剩下警告了,警告部分在CRC校验上。CRC校验这个查表法是否有错呢?我老是觉得怪怪的。
chen3bing 发表于 2010-3-3 12:35 | 显示全部楼层
不好意思,程序没考全。
警告应该不影响,不用管。
查表发可以。
 楼主| cqh250551610 发表于 2010-3-3 12:48 | 显示全部楼层
哦,谢谢了
