【重量级新闻】ST今天发布超值型STM32,面向成本敏感型应用
4499|16
 楼主| 香水城 发表于 2010-3-3 22:42 | 显示全部楼层 |阅读模式
STM32, TI, AN, ce, ic
STMicroelectronics Launches STM32 Value Line to Give Cost-Sensitive Applications Greater Choice
Optimized features of industry’s most accessible STM32 family offer new opportunities for price-sensitive consumer, appliance and industrial designs
Geneva, March 03,2010 - STMicroelectronics (NYSE: STM), a leading supplier of microcontrollers, has released details of new ultra low-cost 32-bit microcontrollers bringing the advantages of the STM32’s 32-bit advanced industry-standard core into applications served by lower-performing devices that lock developers into proprietary processor architectures.
Until now, engineers upgrading legacy 16-bit designs for higher performance and flexibility have had to choose from high-end alternatives that are featured for more complex applications. ST’s new STM32 Value Line remedies this by combining a 24MHz ARM® Cortex™-M3 processor core with peripheral features optimized for typical 16-bit applications such as home-entertainment products, appliances, and industrial equipment. At 24MHz with zero wait state embedded Flash memory access, the STM32 Value Line delivers up to 30 DMIPS, outperforming most of the 16-bit processors. The added advantage of its industry-standard processor, available in devices priced under $1, provides access to a large base of development knowledge and tools.
Application-focused features embedded in the STM32 Value Line include up to 12 16-bit timers, including a PWM timer for motor-control applications. As many as 26 timer channels are available, with package options providing up to 100 pins, as well as a 12-bit high-speed Analog-to-Digital Converter (ADC), to solve a wide range of industrial control challenges. ST is also offering free software support, including a complete 3-phase motor-control library for appliance and motor-control applications and free VDE-certified libraries to help household appliances achieve necessary approval to EN/IEC60335-1 Class B.
The family also embeds hardware support for the Consumer Electronics Control (CEC) protocol included in the HDMI standard, thereby simplifying CEC implementation in products such as TVs, Blu-ray players, PVRs and home cinema equipment. CEC allows up to 10 HDMI devices to discover each other and communicate to manage user-convenience features such as one-touch control of multiple devices via a single remote. Implementing CEC in hardware also frees the processor core to perform extra high-level functions, thereby adding further value to developers’ applications.
In addition, a 12-bit Digital-to-Analog Converter (DAC) allows developers to add audio support in a variety of applications such as security devices or home automation systems, and to address wider opportunities requiring analog waveform generation and control.
The STM32 Value Line links developers into ST’s extensive STM32 family, which now contain five product lines presenting a choice of cost-sensitive, power-sensitive, connectivity-oriented or high-performance microcontrollers. In all, over 110 devices are available, offering a range of features and on-chip memory densities while maintaining pin and software compatibility across all devices. This commonality simplifies strategic processor platform selection by enabling convenient scaling and upgrading of designs, and allowing re-use of intellectual property and development tools to minimize cost and time to market for new products.
The STM32 Value Line microcontrollers are now sampling to lead customers. Volume production will begin from March 2010, at prices from $0.85 for 16Kbyte devices in 48-pin LQFP48 package and $1.44 for 64Kbyte devices in the 64-pin LQFP64 package, for quantities of 10,000 units.
新闻来源:http://www.st.com/stonline/stappl/cms/press/news/year2010/p2479.htm
videre 发表于 2010-3-4 00:01 | 显示全部楼层
这样看,ST不用搞cortex-M0了
IJK 发表于 2010-3-4 09:42 | 显示全部楼层
至少在价格上跟NXP LPC1100系列有得一比:
STM32 Value        $0.85 for 16Kbyte devices in 48-pin LQFP48
LPC1100              $0.65 for 8Kbyte devices in 33-pin QFN33
LPC1100              $0.95 for 32Kbyte devices in 33-pin QFN33
winloop 发表于 2010-3-4 10:31 | 显示全部楼层
要起火了,不过提点建议,既然面向这么低端的应用,那么28、32脚SOP封装的更小规模的片子应该是有需求的,这样的话很多8位机都会被选择出去
bigarmer 发表于 2010-3-4 10:42 | 显示全部楼层
打吧打吧,越激烈越好,价格降下来对中国用户有利啊,LQ捞走中国不少银子!
精益求精 发表于 2010-3-4 11:08 | 显示全部楼层
学不过来了。。一下都喷完算了。三个月一下,受不了了。
IJK 发表于 2010-3-4 13:35 | 显示全部楼层
ST不会这么做的,这么做STM32首先会把STM8的生意抢走了。
这点上面NXP有所不同,可能因为NXP不对8位的LPC系列进行升级了。
 楼主| 香水城 发表于 2010-3-4 15:43 | 显示全部楼层
学东西要学原理,不能只学皮毛。
比如学习使用锤子,难道说学会了大锤子,就不会使用小锤子了?还要再重新学一遍?
agnd 发表于 2010-3-6 10:13 | 显示全部楼层
学东西要学原理,不能只学皮毛。
使大锤子用的是手臂肌肉,比如linux,QT, 使小锤子用的是手腕,比如uCOS,MinGUI,你不重学一遍试试看?
 楼主| 香水城 发表于 2010-3-6 12:17 | 显示全部楼层
如果你在学习的过程中,不能融会贯通、举一反三,总是事倍功半,这是学习方法的问题,这样的话别人是帮不了你的。
微控电子 发表于 2010-3-6 13:22 | 显示全部楼层
说到底,还是ARM公司抢占8bit MCU市场的战略和策略成功了。到了最后,不管是ST还是NXP,都成了ARM的一个棋子,要知道NXP和ST都有自己的MCU,而这些MCU是不需要缴授权费给别家公司的。CM3卖得再好,也是要给ARM公司剥层皮。
sinadz 发表于 2010-3-6 16:46 | 显示全部楼层
这款芯片成本很低吗
司徒老鹰 发表于 2010-3-6 20:08 | 显示全部楼层
何为超值?
McuPlayer 发表于 2010-3-7 19:06 | 显示全部楼层
这个系列的片子值得期待
grant_jx 发表于 2010-3-7 22:05 | 显示全部楼层
这个系列的片子值得期待
早就开卖了,所以不用期待。
VERY0 发表于 2010-3-9 13:49 | 显示全部楼层
斜子 发表于 2010-3-10 00:39 | 显示全部楼层
ARM走的是老盖得策略?当全世界都只会用windows的时候,就是老盖真正发达的时候。
不过MCU市场并没有出现一家独霸的局面,而且也不可能出现这种局面。
认证:意法半导体(中国)投资有限公司
简介:STM32技术专家
596
