我在用CCS3.1仿真2812遇到下列错误是怎么回事?
4165|0
 楼主| redgalaxy 发表于 2010-3-4 17:03 | 显示全部楼层 |阅读模式
Breakpoint Manager: The target will not be run as the breakpoint could not be moved to a valid line at Example_281xFlash.c line 462. It has been disabled.
Breakpoint Manager: Some probe and/or breakpoints were not set at valid lines. Where possible, they have been moved to the next valid line.
Power Failure on Target CPU: Error 0x00001020/-1145 Error during: Execution, Target,  Unrecoverable emulation error  Sequence ID: 16 Error Code: -1145 Error Class: 0x00001020
Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint opcodes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging.
