[Kinetis] KL03官方例程low_power_demo遇到问题
1151|0
 楼主| 519825192 发表于 2016-5-28 13:55 | 显示全部楼层 |阅读模式
每次我刚输入“9”时,程序就进入VLLS3,然后又直接从VLLS3中退出来了(没有其他操作,和唤醒信号,只用键盘发送了一个“9”)。现象如下:,求解释。
2016-05-28 13:43:26
Running the LowPower_demo project.
Software Reset
KL03 Power Manag
2016-05-28 13:43:26 erment Test, can test the Idd in all kinds of mode.
0.Run     mode
1.Wait    mode
2.PStop2  mode
3.PStop1  mode
4.Stop    mode
5.VLPR    mode
6.VLPW    mode
7.VLPS    mode
8.LLS     mode-->Not Suppo
2016-05-28 13:43:27 rt
9.VLLS3   mode
A(a).VLLS1 mode
B(b).VLLS0-1 mode -- POR ON
C(c).VLLS0-2 mode -- POR OFF
Please press reset button to wake up MCU for VLLS0 mode
2016-05-28 13:43:27 *******************
Enter the key number to choose one mode:
2016-05-28 13:43:56 9
2016-05-28 13:44:06  LLWU configured pins PTB0 is LLWU wakeup source
LLWU PE1   = 0x00,    LLWU PE2   = 0x02
LLWU
2016-05-28 13:44:06  ME    = 0x00,    LLWU F1    = 0x00
LLWU F3    = 0x00
LLWU FILT1 = 0x00,
enter into VLLS3 mode--.
2016-05-28 13:44:06
[outSRS]Wakeup bit set from low po
2016-05-28 13:44:07 wer mode exit
[outSRS]SMC_PMPROT   = 0x22
[outSRS]SMC_PMCTRL   = 0x04
[outSRS]SMC_STOPCTRL   = 0x03
[outSRS]SMC_PMSTAT   = 0x01
[outSRS] VLLS3 exit
2016-05-28 13:44:07 *******
KL03 Power Managerment Test, can test the Idd in all kinds of mode.
0.Run     mode
1.Wait    mode
2.PStop2  mode
3.PStop1  mode
4.Stop    mode
5.VLPR    mode
6.VLPW    mode
2016-05-28 13:44:07
7.VLPS    mode
8.LLS     mode-->Not Support
9.VLLS3   mode
A(a).VLLS1 mode
2016-05-28 13:44:07 ********************************************************
2016-05-28 13:49:02 9
LLWU ME    = 0x00,    LLWU F1    = 0x00
LLWU F3    = 0x00
LLWU FILT1 = 0x00,
2016-05-28 13:49:02
[outSRS]Wakeup bit set from low power mode exit
2016-05-28 13:49:02 22
[outSRS] VLLS3 exit
KL03 Power
2016-05-28 13:49:02 Managerment Test, can test the Idd in all kinds of mode.
0.Run     mode
1.Wait    mode
2.PStop2  mode
3.PStop1  mode
4.Stop    mode
5.VLPR    mode
6.VLPW    mode
7.VLPS    mode
2016-05-28 13:49:02
9.VLLS3   mode
A(a).VLLS1 mode
2016-05-28 13:49:02 ****************
2016-05-28 13:49:09 9
LLWU F3    = 0x00
2016-05-28 13:49:09
LLWU FILT1 = 0x00,
2016-05-28 13:49:09
[outSRS] VLLS3 exit
2016-05-28 13:49:09
0.Run     mode
1.Wait    mode
2.PStop2  mode
3.PStop1
2016-05-28 13:49:09 mode
4.Stop    mode
5.VLPR    mode
6.VLPW    mode
7.VLPS    mode
9.VLLS3   mode
A(a).VLLS1 mode
Please press
2016-05-28 13:49:10  reset button to wake up MCU for VLLS0 mode
2016-05-28 13:49:13 9
LLWU F3    = 0x00
LLWU FILT1 = 0x00,
2016-05-28 13:49:13
[outSRS]SMC_PMPRO
2016-05-28 13:49:13 T   = 0x22
[outSRS] VLLS3 exit
KL03 Power Managerm
2016-05-28 13:49:13 ent Test, can test the Idd in all kinds of mode.
0.Run     mode
1.Wait    mode
2.PStop2  mode
3.PStop1  mode
4.Stop    mode
5.VLPR    mode
6.VLPW    mode
7.VLPS    mode
8.LLS     mod
2016-05-28 13:49:13 e-->Not Support
9.VLLS3   mode
A(a).VLLS1 mode
2016-05-28 13:49:13 ************************
2016-05-28 13:52:59 0
LLWU F3
2016-05-28 13:52:59  = 0x00
LLWU FILT1 = 0x00,
