[DemoCode下载] NUC123两套代码切换执行
2173|8
 楼主| chenwenbin1984 发表于 2016-5-30 11:12 | 显示全部楼层 |阅读模式
[NUC123]APROM两套代码切换执行.zip (550.06 KB, 下载次数: 41)
玛尼玛尼哄 发表于 2016-5-31 10:47 | 显示全部楼层
还可以这样,这是不是就相当于程序分支啊、
heisexingqisi 发表于 2016-5-31 20:05 | 显示全部楼层
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 8 $
  5. * $Date: 15/07/02 11:18a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate how to set GPIO pin mode and use pin data input/output control.
  7. * @note
  8. * Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
  9. ******************************************************************************/
  10. #include <stdio.h>
  11. #include "NUC123.h"
  12. #define HCLK_CLOCK           72000000
  13. void SYS_Init(void)
  14. {
  15.     /*---------------------------------------------------------------------------------------------------------*/
  16.     /* Init System Clock        */
  17.     /*---------------------------------------------------------------------------------------------------------*/
  18.     /* Enable XT1_OUT(PF0) and XT1_IN(PF1) */
  19. //    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
  20.     /* Enable Internal RC 22.1184MHz clock */
  21.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  22.     /* Waiting for Internal RC clock ready */
  23.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  24.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  25.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  26. //    /* Enable external XTAL 12MHz clock */
  27. //    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  28. //    /* Waiting for external XTAL clock ready */
  29. //    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  30. //    /* Set core clock as HCLK_CLOCK */
  31. //    CLK_SetCoreClock(HCLK_CLOCK);
  32. //    /* Enable UART module clock */
  33. //    CLK_EnableModuleClock(UART0_MODULE);
  34. //    /* Select UART module clock source */
  35. //    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  36. //    /*---------------------------------------------------------------------------------------------------------*/
  37. //    /* Init I/O Multi-function        */
  38. //    /*---------------------------------------------------------------------------------------------------------*/
  39. //    /* Set GPB multi-function pins for UART0 RXD(PB.0) and TXD(PB.1) */
  40. //    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
  41. //    SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD);
  42. }
  43. void UART0_Init()
  44. {
  45.     /*---------------------------------------------------------------------------------------------------------*/
  46.     /* Init UART        */
  47.     /*---------------------------------------------------------------------------------------------------------*/
  48.     /* Reset UART0 module */
  49.     SYS_ResetModule(UART0_RST);
  50.     /* Configure UART0 and set UART0 Baudrate */
  51.     UART_Open(UART0, 115200);
  52. }
  53. uint16_t Light = 10 ;                       //Time lengh of LED lighting. MAX value = PERIOD_LIGHT
  54. typedef void (FUNC_PTR)(void);
  55. __asm spChange(uint32_t _sp)
  56. {
  57.         MSR MSP, r0
  58.         BX lr
  59. }
  60. /*---------------------------------------------------------------------------------------------------------*/
  61. /* MAIN function        */
  62. /*---------------------------------------------------------------------------------------------------------*/
  63. int main(void)
  64. {
  65.   FUNC_PTR                  *func;
  66.         volatile uint32_t  time=20, a, _sp;
  67.
  68.         SYS_Init() ;
  69.   GPIO_SetMode(PB, BIT4, GPIO_PMD_OUTPUT);
  70.
  71.         while(time--)
  72.         {
  73.     PB4 = 0;
  74.                 for(a=0;a<50000;a++);
  75.                 PB4 = 1;
  76.                 for(a=0;a<50000;a++);
  77.         }
  78.
  79.   SYS_UnlockReg();
  80.
  81.   SYS->IPRSTC2=0xFFFFFFFF;      //复位所有外设
  82.         SYS->IPRSTC2=0x0;
  83.   NVIC->ICER[0] = 0xFFFFFFFF;   //关闭中断
  84.
  85.         CLK->APBCLK |= CLK_AHBCLK_ISP_EN_Msk;
  86.         FMC->ISPCON |=1;
  87.   FMC->ISPCMD=0x2E;
  88.         FMC->ISPADR =0x3000;    //设置向量映射的地址
  89.         FMC->ISPTRG|=1;
  90.
  91.         __ISB();
  92.
  93.         _sp = *(volatile uint32_t *) 0x3000;
  94.         spChange(_sp);               //设置堆栈
  95.         func = (FUNC_PTR *)(*(uint32_t *)(0x3000 + 4)); //函数指针指向第二套代码的复位向量
  96.         func();                //跳到第二套代码执行
  97.
  98.         while(1);
  99. }
heisexingqisi 发表于 2016-5-31 20:06 | 显示全部楼层
  2. * @file     main.c
  3. * @version  V3.00
  4. * $Revision: 8 $
  6. * @brief    Demonstrate how to set GPIO pin mode and use pin data input/output control.
  7. * @note
  14. {
  42. }
  44. {
  46.     /* Init UART        */
  52. }
  56. {
  57.         MSR MSP, r0
  58.         BX lr
  59. }
  63. int main(void)
  64. {
  65.   FUNC_PTR                  *func;
  66.         volatile uint32_t  time=10, a, _sp;
  67.
  68.         SYS_Init() ;
  70.
  71.         while(time--)
  72.         {
  73.     PB4 = 0;
  74.                 for(a=0;a<150000;a++);
  75.                 PB4 = 1;
  76.                 for(a=0;a<150000;a++);
  77.         }
  78.
  80.
  84.
  88.         FMC->ISPADR =0x0000;    //设置向量映射的地址
  89.         FMC->ISPTRG|=1;
  90.
  91.         __ISB();
  92.
  93.         _sp = *(volatile uint32_t *) 0x0000;
  95.         func = (FUNC_PTR *)(*(uint32_t *)(0x0000 + 4)); //函数指针指向第一套代码的复位向量
  96.         func();                //跳到第一套代码执行
  97.
  98.         while(1);
  99. }
玛尼玛尼哄 发表于 2016-5-31 21:48 | 显示全部楼层
原来是通过指针实现的啊,看来指针真的很强大。
wahahaheihei 发表于 2016-5-31 23:13 | 显示全部楼层
zhuotuzi 发表于 2016-6-1 17:21 | 显示全部楼层
思路很不错,不过我还没有遇到过这种应用需求。
wangjiqiang2017 发表于 2017-9-15 17:12 | 显示全部楼层
两个代码怎么烧录到单片机里,用什么软件,用什么方法啊?能讲讲吗?
wangjiqiang2017 发表于 2017-9-15 17:37 | 显示全部楼层
如何烧录已经了解,但还有个问题,
如果程序有中断,那中断向量要怎么对应?
