[i.MX] ubuntu16.04下编译L3.0.35_4.1.0_130816_source --ltib时出错
3772|3
 楼主| jianwei1001 发表于 2016-5-30 11:39 | 显示全部楼层 |阅读模式
在编译L3.0.35_4.1.0_130816_source  ltib时出现如下错误,本人刚接触linux这块,不知如何解决了,请大神们帮忙解答下,不甚感激。本人积分不多,只能意思下了~~~~
错误如下:
jian@jian-OptiPlex-GX620:~/software/iMX6/L3.0.35_4.1.0_130816_source/ltib/ltib$ ./ltib
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/(%{ <-- HERE ?([^}]+)}?)/ at /home/jian/software/iMX6/L3.0.35_4.1.0_130816_source/ltib/ltib/bin/Ltibutils.pm line 237.
Can't use 'defined(@array)' (Maybe you should just omit the defined()?) at /home/jian/software/iMX6/L3.0.35_4.1.0_130816_source/ltib/ltib/bin/Ltibutils.pm line 362.
Compilation failed in require at ./ltib line 39.
BEGIN failed--compilation aborted at ./ltib line 39.
烂了的芋头 发表于 2016-6-20 10:08 | 显示全部楼层
哥们,这个问题解决了吗?我也碰到这个问题了。谢谢!
asdf112255 发表于 2016-10-26 14:46 | 显示全部楼层
求解决 方案,我的 也是这样
ddxx 发表于 2017-9-4 15:15 | 显示全部楼层
jiang { gaiwei [{],jiukeyile
