接收的时候接收不到
1290|13
 楼主| liliang9554 发表于 2016-6-4 17:27 | 显示全部楼层 |阅读模式
MSP430F149这个芯片。利用usart时出现了这样一个现象:usart0在波特率2400,4800,9600,38400下都能实现收发,usart1在波特率2400,4800,9600,19200,下实现收发也没有问题,在38400波特率下发送也没有问题,就是在接收的时候接收不到
heweibig 发表于 2016-6-4 17:29 | 显示全部楼层
你测试什么情况
 楼主| liliang9554 发表于 2016-6-4 17:33 | 显示全部楼层
串口发送FF,RXBUF1接收到FE,发送FE,RXBUF1接收到FC,发送FC,RXBUF1接收到F8,发送F8,RXBUF1接收到F0,发送F0,RXBUF1接收到E0,发送E0,接收C0,发送C0,接收80,发送80,接收00。发送EF,接收CE,发送CF,接收8E,发送8F,接收0E。7F及小于7F的接收不到。这个问题是怎么回事?
jiahy 发表于 2016-6-4 17:34 | 显示全部楼层
貌似接受的数据总是比发出来的小啊,好奇怪
lizye 发表于 2016-6-4 17:36 | 显示全部楼层
能上传一下你的电路图和程序吗
 楼主| liliang9554 发表于 2016-6-4 17:40 | 显示全部楼层
#include <msp430x14x.h>
#define MAX_RD_LEN      16
void Init_sys(void);
void Init_Uart(void);
unsigned char Receive[MAX_RD_LEN+3+1]={0};             //receive byte
unsigned int  Receive_Cnt=0;
unsigned char R_Time_cnt=0;
unsigned char R_Flag=0;
unsigned char R_End_Flag=0;                //If receive end flag equal 1,then receive end and storage message.
unsigned char Tmp_data_Len=0;
unsigned char *R_Data_Ptr=(unsigned char *)0x1000;//Storage message pointer;
void main(void)
  unsigned char i;
  Init_sys();
  Init_Uart();
  U0TCTL |=TXEPT;
  while(1)
    if(R_End_Flag==1)
         if((Receive[0]==0xAA)&&(Receive[1]==0x00)&&(Receive[2]==0x00))
           if(Receive_Cnt>MAX_RD_LEN+3) //if the length that program receive is longer than max receive data length,initialize the length.
              Receive_Cnt=MAX_RD_LEN+3;
           Tmp_data_Len=Receive_Cnt-3;
           WDTCTL=WDTPW+WDTHOLD;        //Disable WDT
           _DINT();                     //Disable interrupts
           while((BUSY&FCTL3)==1);      //Test BUSY  Loop while busy
           FCTL2=FWKEY+FSSEL1+FN0;      //SMCLK/2
           FCTL3=FWKEY;                 //Clear LOCK
           FCTL1=FWKEY+ERASE;           //Enable erase
           *R_Data_Ptr=0;
           FCTL1=FWKEY+WRT;             //Enable write and Disable erase
           *R_Data_Ptr++=Tmp_data_Len;  //First byte for storaging data length
           for(i=3;i<Receive_Cnt;i++)
             *R_Data_Ptr++=Receive[i];
           FCTL3=FWKEY+LOCK;            //Done, set LOCK
           _EINT();                     //Enable interrupts
           R_Data_Ptr=(unsigned char *)0x1000;  //initialize pointer
           if(*R_Data_Ptr==Receive_Cnt-3)
             //P5OUT|=RTS10;                //485处于发送状态
             TXBUF1=0xAA;
             while((U1TCTL&0x01)==0);
             TXBUF1=0x00;
             while((U1TCTL&0x01) ==0);
             TXBUF1=0x00;
             //P5OUT&=~RTS10;               //485处于接收状态
         if((Receive[0]==0xAB)&&(Receive[1]==0x00)&&(Receive[2]==0x00))
            TXBUF1=0xAB;
            TXBUF1=0x00;
            TXBUF1=0x00;
            if(*R_Data_Ptr==0xFF)
               TXBUF1=0x00;
            else
               Tmp_data_Len=*R_Data_Ptr++;
               for(i=0;i<Tmp_data_Len;i++)
                 TXBUF1=*R_Data_Ptr++;
         Receive_Cnt=0;
         R_End_Flag=0;                  //wait for next
void Init_sys(void)               //Initalize MSP430 system
  unsigned char i;
//New:switch 7.3728MHZ and 32768HZ
WDTCTL=WDTPW+WDTHOLD;             //Stop WDT
BCSCTL1 &=~(XT2OFF+XTS);         //LFXT1 = LF XTAL and Put on XT2!
//BCSCTL1 |=DIVA_3;
do
    IFG1 &=~OFIFG;                  //Clear OSC fault flag
    for (i=0xFF;i>0;i--);         // i = Delay*/
while((IFG1 & OFIFG)!=0);       //OSC fault flag set?
BCSCTL2 |=(SELM_2+SELS);
BCSCTL2 |=(DIVS0+DIVS1);         //;SMCKLK 分频8
//TIMERA 10ms
TACTL=TASSEL_2+MC0+TACLR;
CCTL0=CCIE;                      //捕获/比较寄存器CCR0
CCR0=9216-1;                     //CCR0  counts to 10ms;
return;
     UCTL1=CHAR+SWRST;              //8-bit characters(p216)
     UTCTL1=SSEL1;                  //SMCLK;
     switch(3)
      case 3:
           UBR01=0x18;              //38400;
           UBR11=0x00;
     UMCTL1=0x00;                  //7.3728MHz no modulation 115200
     UCTL1 &=~SWRST;
     ME2 |=(UTXE1+URXE1);          //Enable USART0 TXD/RXD
     IE2 |=URXIE1;                 //Enable USART0 RX interrupt
     P3SEL |=0xC0;                 //P3.6,7 = USART0 TXD/RXD
     P3DIR |=0x40;                 //P3.6 = output direction
    _EINT();
#pragma vector=TIMERA0_VECTOR      //在IAR2.0以上中断函数声明。
__interrupt void TIMERA0_rx (void)
     if(R_Flag==1)      //when R_Flag=1,receive time count add.
        R_Time_cnt++;
        if(R_Time_cnt>=2)
          R_End_Flag=1;   //receive end and begin to handle in main
          R_Time_cnt=0;   //intialize R_Time_cnt 0
          R_Flag=0;       //count stop
//用来控制单片机与上位机之间的通信  232通信,注意:波特率38400行不通
#pragma vector=UART1RX_VECTOR
__interrupt void usart1_rx (void)
  Receive[Receive_Cnt]=RXBUF1;
  Receive_Cnt++;
  R_Flag=1;                     //begin to count
  R_Time_cnt=0;                 //restart to count
huangchui 发表于 2016-6-4 17:41 | 显示全部楼层
硬件电路没问题吧
 楼主| liliang9554 发表于 2016-6-4 17:45 | 显示全部楼层
硬件电路时没有问题的。usart1
连接光耦,连接max202e,连接电脑。我再2400,4800,9600,19200下测试了,都能实现双向通讯
jlyuan 发表于 2016-6-4 17:47 | 显示全部楼层
38400呢
 楼主| liliang9554 发表于 2016-6-4 17:48 | 显示全部楼层
38400下可实现发送,但不能实现接收
wuhany 发表于 2016-6-4 17:50 | 显示全部楼层
USART0和USART1还是有区别的是吗?
 楼主| liliang9554 发表于 2016-6-4 17:52 | 显示全部楼层
在USART0下实现发送和接收知道115200还是很好的。这是怎么个情况,谁给解释一下呢?
jiaxw 发表于 2016-6-4 17:55 | 显示全部楼层
木碰到过。。。
 楼主| liliang9554 发表于 2016-6-4 17:58 | 显示全部楼层
哦,算了把,周一再看看,多谢大家了啊
