[i.MX] bitbake fsl-image-gui 错误
1421|3
 楼主| yuereye 发表于 2016-6-7 16:43 | 显示全部楼层 |阅读模式
使用i.MX6开发板进行开发环境搭建时发现一个现象:使用bitbake fsl-image-gui编译时会提示如下错误:
请大神解答,谢谢
-Wl,-rpath,/home/wf/iMx6/fsl-release-bsp/build-x11/tmp/sysroots/i686-linux/lib -Wl,-O1 -o build/genconditions \
|             build/genconditions.o build/rtl.o build/read-rtl.o build/ggc-none.o build/vec.o build/min-insn-modes.o build/gensupport.o build/print-rtl.o build/read-md.o build/errors.o ../build-i686-linux/libiberty/libiberty.a
| build/genpreds -c /home/wf/iMx6/fsl-release-bsp/build-x11/tmp/work-shared/gcc-4.9.1-r0/gcc-4.9.1/gcc/config/arm/arm.md > tmp-constrs.h
| g++    -isystem/home/wf/iMx6/fsl-release-bsp/build-x11/tmp/sysroots/i686-linux/usr/include -O2 -pipe -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -DGENERATOR_FILE -static-libstdc++ -static-libgcc -L/home/wf/iMx6/fsl-release-bsp/build-x11/tmp/sysroots/i686-linux/usr/lib -L/home/wf/iMx6/fsl-release-bsp/build-x11/tmp/sysroots/i686-linux/lib -Wl,-rpath-link,/home/wf/iMx6/fsl-release-bsp/build-x11/tmp/sysroots/i686-linux/usr/lib -Wl,-rpath-link,/home/wf/iMx6/fsl-release-bsp/build-x11/tmp/sysroots/i686-linux/lib -Wl,-rpath,/home/wf/iMx6/fsl-release-bsp/build-x11/tmp/sysroots/i686-linux/usr/lib -Wl,-rpath,/home/wf/iMx6/fsl-release-bsp/build-x11/tmp/sysroots/i686-linux/lib -Wl,-O1 -o build/genattr \
|             build/genattr.o build/rtl.o build/read-rtl.o build/ggc-none.o build/vec.o build/min-insn-modes.o build/gensupport.o build/print-rtl.o build/read-md.o build/errors.o ../build-i686-linux/libiberty/libiberty.a
| build/genpreds: Internal error: abort in copy_rtx, at rtl.c:324
| make[1]: *** [s-constrs-h] Error 1
| make[1]: *** Waiting for unfinished jobs....
| rm gcc.pod
| make[1]: Leaving directory `/home/wf/iMx6/fsl-release-bsp/build-x11/tmp/work/i686-poky-linux-gnueabi/gcc-cross-arm/4.9.1-r0/gcc-4.9.1/build.i686-linux.arm-poky-linux-gnueabi/gcc'
| make: *** [all-gcc] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/wf/iMx6/fsl-release-bsp/build-x11/tmp/work/i686-poky-linux-gnueabi/gcc-cross-arm/4.9.1-r0/temp/log.do_compile.24319)
ERROR: Task 758 (/home/wf/iMx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross_4.9.bb, do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 242 tasks of which 16 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
wf@wf-Lenovo:~/iMx6/fsl-release-bsp/build-x11$
alex0321 发表于 2016-6-30 14:41 | 显示全部楼层
我目前也在玩imx6的开发板
alex0321 发表于 2016-6-30 14:43 | 显示全部楼层
你是不是用了最新的ubuntu 16.04 LTS,目前ubuntu16支持不好,容易出问题
alex0321 发表于 2016-6-30 14:54 | 显示全部楼层
不管你用的是那个发行版,都暂且不要用最新版本,按照错误来看,没有fetch错误,基本上都是compile错误。
