[i.MX] Kernel panic - not syncing: No init found.
1021|0
 楼主| ricky6688 发表于 2016-6-9 16:27 | 显示全部楼层 |阅读模式
Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[<80048854>] (unwind_backtrace+0x0/0xf8) from [<8052aa34>] (panic+0x74/0x18c)
[<8052aa34>] (panic+0x74/0x18c) from [<8052a748>] (init_post+0xa0/0xc4)
[<8052a748>] (init_post+0xa0/0xc4) from [<800089b4>] (kernel_init+0x10c/0x13c)
[<800089b4>] (kernel_init+0x10c/0x13c) from [<80042aa4>] (kernel_thread_exit+0x0/0x8)
CPU1: stopping
[<80048854>] (unwind_backtrace+0x0/0xf8) from [<8003c324>] (do_IPI+0x150/0x17c)
[<8003c324>] (do_IPI+0x150/0x17c) from [<80041a0c>] (__irq_svc+0x4c/0xe8)
Exception stack(0xbfc7fe98 to 0xbfc7fee0)
fe80:                                                       80ad3804 bfafb3f8
fea0: 00000000 80002001 00000012 80b1ab7c 80ad3900 00000004 80acdac4 3b5dc100
fec0: 00000001 805332c4 fffffffe bfc7fee0 800633bc 8005987c 20000013 ffffffff
[<80041a0c>] (__irq_svc+0x4c/0xe8) from [<8005987c>] (_clk_pll2_main_get_rate+0x2c/0x3c)
[<8005987c>] (_clk_pll2_main_get_rate+0x2c/0x3c) from [<800633bc>] (clk_get_rate+0x40/0x50)
[<800633bc>] (clk_get_rate+0x40/0x50) from [<80057498>] (pfd_get_rate+0x14/0x68)
[<80057498>] (pfd_get_rate+0x14/0x68) from [<800633bc>] (clk_get_rate+0x40/0x50)
CPU2: stopping
Exception stack(0xbffb5f90 to 0xbffb5fd8)
5f80:                                     80b21680 60000093 00000001 00000000
5fa0: bffb4000 80b1a224 80acda70 805332c0 80ad0f9c 412fc09a 00000000 00000000
5fc0: 00000000 bffb5fd8 8005076c 80042b04 40000013 ffffffff
[<80041a0c>] (__irq_svc+0x4c/0xe8) from [<80042b04>] (default_idle+0x24/0x28)
[<80042b04>] (default_idle+0x24/0x28) from [<80042d20>] (cpu_idle+0xe0/0x124)
[<80042d20>] (cpu_idle+0xe0/0x124) from [<10527874>] (0x10527874)
CPU3: stopping
Exception stack(0xbff01f90 to 0xbff01fd8)
1f80:                                     80b21680 80000093 00000001 00000000
1fa0: bff00000 80b1a224 80acda70 805332c0 80ad0f9c 412fc09a 00000000 00000000
1fc0: 00000000 bff01fd8 8005076c 80042b04 40000013 ffffffff
有没有遇到这样的问题
