提供全套TCC8900/TCC8901/TCC8902开发资源
3651|0
 楼主| emboard 发表于 2010-3-9 17:39 | 显示全部楼层 |阅读模式
tc, AN, ST, ic, AC
韩国TELECHIPS公司TCC89XX芯片是采用65nm工艺制造的,主频超过600MHz,视频解码最高支持1980*1080分辨率.
The TCC8900 is the system LSI for digital ** applications which based on ARM1176JZF-S, ARM’s proprietary RISC
CPU core. It can decode and encode various types of video and audio standards by software and dedicated hardware
accelerators – JPEG / MPEG1 / MPEG2 / MPEG4-SP/ASP / H.264 / VC-1 / RV and other types of video standard and MP3 /
AAC / MPEG4-AAC / MPEG4-BSAC and other types of standard for audio.
The on-chip high speed USB2.0 device controller enables the data transmission between a personal computer and storage
device such as NAND flash, HDD, CD, SD, MMC and Memory Stick etc, which can be controlled by the TCC8900.
有诚意者请速联系:QQ:1411358874
                  EMAIL:EMBOARD@YEAH.NET
1.完全提供相关芯片技术手册,最新开发板硬件图纸
2.完全提供WINCE6.0 BSP开发包(BSP和视频编解码)以及相关编译步骤和下载烧写方法手册
3.完全提供LINUX BSP开发包(BSP和视频编解码)以及相关编译步骤和下载烧写方法手册
4.如需要可以协助调试BSP,直到板子跑起来
芯片详情请查看附件(TCC8900_CHIP_SPEC)
