为什么我的AD转换程序只能由EVA的定时器2启动?
2786|1
 楼主| redgalaxy 发表于 2010-3-10 10:39 | 显示全部楼层 |阅读模式
我使用的时2812   CCS3.1
void init_eva_timer1(void)
    // Initialize EVA Timer 1:
    // Setup Timer 1 Registers (EV A)
    EvaRegs.GPTCONA.all = 0;
    // Set the Period for the GP timer 1 to 0x0200;
    EvaRegs.T1PR = 0x0200;       // Period
    EvaRegs.T1CMPR = 0x0000;     // Compare Reg
    // Enable Period interrupt bits for GP timer 1
    // Count up, x128, internal clk, enable compare, use own period
    EvaRegs.EVAIMRA.bit.T1PINT = 1;
    EvaRegs.EVAIFRA.bit.T1PINT = 1;
    // Start EVA ADC Conversion on timer 1 Period interrupt   周期中断启动ADC
    EvaRegs.GPTCONA.bit.T1TOADC = 2;
    // Clear the counter for GP timer 1    连续增计数模式
    EvaRegs.T1CNT = 0x0000;
    EvaRegs.T1CON.all = 0x1742;
void init_eva_timer2(void)
    // Initialize EVA Timer 2:
    // Setup Timer 2 Registers (EV A)
    // Set the Period for the GP timer 2 to 0x0200;
    EvaRegs.T2PR = 0x0400;       // Period
    EvaRegs.T2CMPR = 0x0000;     // Compare Reg
    // Enable Period interrupt bits for GP timer 2
    EvaRegs.EVAIMRB.bit.T2PINT = 1;
    EvaRegs.EVAIFRB.bit.T2PINT = 1;
    // Clear the counter for GP timer 2
    EvaRegs.T2CNT = 0x0000;
    EvaRegs.T2CON.all = 0x1742;
    //Start EVA ADC Conversion on timer 2 Period interrupt
    //EvaRegs.GPTCONA.bit.T2TOADC = 2;只能由定时器2启动,屏蔽该位AD转换就不正确
哪位大虾给一下合理的解释!
 楼主| redgalaxy 发表于 2010-3-10 20:30 | 显示全部楼层
我又看了一遍程序,发现两个定时器如果都初始化的话,只能使用timer2来周期中断AD
如果屏蔽掉timer2的初始化,那么timer1就可以周期中断启动AD了,这种现象怎么这么怪呢?
