[疑难问答] 想进入RXNE中断 反而进入不来
994|9
 楼主| xia00 发表于 2016-6-18 07:59 | 显示全部楼层 |阅读模式
请教一个串口相关的问题,代码如下:
void Uart_Port_Init(void)   ?配置端口
        GPIO_InitTypeDef         GPIO_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
//         USART_DeInit(USART1);
        /* Connect PXx to USARTx_Tx */
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1);
        /* Connect PXx to USARTx_Rx */
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_USART1);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
void Uart_Init(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        USART_ClockInitTypeDef        USART_Clock_InitStructure;
        USART_InitTypeDef        USART_InitStructure;
        USART_InitStructure.USART_BaudRate = 9600;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;//USART_Parity_Even;
        USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_Init(USART1, &USART_InitStructure);
        USART_Clock_InitStructure.USART_Clock = USART_Clock_Disable;
        USART_Clock_InitStructure.USART_CPOL = USART_CPOL_Low;                                                  //²»Ê¹ÓÃͬ²½Ä£Ê½
        USART_Clock_InitStructure.USART_CPHA = USART_CPHA_2Edge;
        USART_Clock_InitStructure.USART_LastBit = USART_LastBit_Disable;
        USART_ClockInit(USART1,&USART_Clock_InitStructure);
        USART_ClearFlag(USART1,USART_IT_RXNE);
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
        USART_ClearFlag(USART1,USART_IT_TXE);
        USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
        USART_ClearFlag(USART1,USART_FLAG_TC);
        USART_ITConfig(USART1, USART_IT_TC, ENABLE);
//         USART_Cmd(USART1, ENABLE);
        USART1->CR1 |= 0x0006;
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
void USART1_IRQHandler(void)
        INT8U Temp;
        if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
                USART_ClearITPendingBit(USART1,USART_IT_RXNE);
                Temp = USART_ReceiveData(USART1);
                USART_SendData(USART1,Temp);
        if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
                USART_ClearITPendingBit(USART1,USART_IT_TXE);
                USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
//                 USART1->SR &= ~(1<<7);
结果程序一直进入TXE中断,仿真时TXE一直为1,专门清也清不掉,想进入RXNE中断。反而进入不了。
hfdy01 发表于 2016-6-18 08:00 | 显示全部楼层
貌似发送完了,要关发送中断,不然就是一直进的.
CallReceiver 发表于 2016-6-18 08:11 | 显示全部楼层
USART_ClearFlag(USART1,USART_FLAG_TC); USART_ITConfig(USART1, USART_IT_TC, ENABLE); 去掉这2句试下
boy1990 发表于 2016-6-18 08:16 | 显示全部楼层
只要开了中断,就一定要发数据的吧..
boy1990 发表于 2016-6-18 08:25 | 显示全部楼层
去掉这2句试下;
sourceInsight 发表于 2016-6-18 08:59 | 显示全部楼层
开了发送中断,就一定要发数据,
不开中断,你何必管TXE呢...
 楼主| xia00 发表于 2016-6-18 09:11 | 显示全部楼层
USART_ClearFlag(USART1,USART_FLAG_TC); USART_ITConfig(USART1, USART_IT_TC, ENABLE); 去掉这2句试下 ...
如果不加上这一句的话,不仅TXE一直为1,而且TC也一直为1
 楼主| xia00 发表于 2016-6-18 09:12 | 显示全部楼层
开了发送中断,就一定要发数据,
不开中断,你何必管TXE呢...
我可以不管TXE,但问题是接受中断也进不去
bbapple 发表于 2016-6-18 09:13 | 显示全部楼层
是不是你在接收中断里 发送数据了 然后又开了发送中断  所以才会一直进入到中断里面啊?
handleMessage 发表于 2016-6-18 09:20 | 显示全部楼层
建议你调试的时候 在每个中断里加个调试信息。你好确定每次进入的是哪个中断啊。
