[i.MX] imx6 Android4.4.3 怎么降低功耗呢?
1284|0
 楼主| houyizi313 发表于 2016-6-29 10:37 | 显示全部楼层 |阅读模式
我们用imx6dl 跑Android4.4.3(kernel3.10.53),系统无法进入深度休眠?关屏后功耗还是500多mA;特别的费电;
cpus {
                #address-cells = <1>;
                #size-cells = <0>;
                cpu0: cpu@0 {
                        compatible = "arm,cortex-a9";
                        device_type = "cpu";
                        reg = <0>;
                        next-level-cache = <&L2>;
                        operating-points = <
                                /* kHz    uV */
                                996000  1275000
                                792000  1175000
                                396000  1150000
                        fsl,soc-operating-points = <
                                /* ARM kHz      SOC-PU uV */
                                996000            1175000
                                792000            1175000
                                396000            1175000
                        clock-latency = <61036>; /* two CLK32 periods */
                        clocks = <&clks 104>, <&clks 6>, <&clks 16>,
                                 <&clks 17>, <&clks 170>;
                        clock-names = "arm", "pll2_pfd2_396m", "step",
                                      "pll1_sw", "pll1_sys";
                        arm-supply = <&reg_arm>;
                        pu-supply = <&reg_pu>;
                        soc-supply = <&reg_soc>;
                cpu@1 {
                        reg = <1>;
