TMS320F28335的时钟介绍
973|4
 楼主| Rollo 发表于 2016-6-30 21:14 | 显示全部楼层 |阅读模式
TMS320F28335上有一个基于PLL电路的片上时钟模块,为CPU及外设提供时钟有两种方式:一种是用外部的时钟源,将其连接到X1引脚上或者XCLKIN引脚上,X2接地;另一种是使用振荡器产生时钟,用30MHz的晶体和两个20PF的电容组成的电路分别连接到X1和X2引脚上,XCLKIN引脚接地。我们常用第二种来产生时钟。此时钟将通过一个内部PLL锁相环电路,进行倍频。由于F28335的最大工作频率是150M,所以倍频值最大是5。其中倍频值由PLLCR的低四位和PLLSTS的第7、8位来决定。其详细的倍频值可以参照TMS320F28335的Datasheet。下面是F28335的时钟设置:
void InitPll(Uint16 val, Uint16 divsel)
// Make sure the PLL is not running in limp mode
   if (SysCtrlRegs.PLLSTS.bit.MCLKSTS != 0)
      // Missing external clock has been detected
      // Replace this line with a call to an appropriate
      // SystemShutdown(); function.
      asm("        ESTOP0");
   // DIVSEL MUST be 0 before PLLCR can be changed from
   // 0x0000. It is set to 0 by an external reset XRSn
   // This puts us in 1/4
   if (SysCtrlRegs.PLLSTS.bit.DIVSEL != 0)
       EALLOW;
       SysCtrlRegs.PLLSTS.bit.DIVSEL = 0;
       EDIS;
   // Change the PLLCR
   if (SysCtrlRegs.PLLCR.bit.DIV != val)
      EALLOW;
      // Before setting PLLCR turn off missing clock detect logic
      SysCtrlRegs.PLLSTS.bit.MCLKOFF = 1;
      SysCtrlRegs.PLLCR.bit.DIV = val;
      EDIS;
      // Optional: Wait for PLL to lock.
      // During this time the CPU will switch to OSCCLK/2 until
      // the PLL is stable.  Once the PLL is stable the CPU will
      // switch to the new PLL value.
      // This time-to-lock is monitored by a PLL lock counter.
      // Code is not required to sit and wait for the PLL to lock.
      // However, if the code does anything that is timing critical,
      // and requires the correct clock be locked, then it is best to
      // wait until this switching has completed.
      // Wait for the PLL lock bit to be set.
      // The watchdog should be disabled before this loop, or fed within
      // the loop via ServiceDog().
    // Uncomment to disable the watchdog
      DisableDog();
      while(SysCtrlRegs.PLLSTS.bit.PLLLOCKS != 1)
       // Uncomment to service the watchdog
          // ServiceDog();
      EALLOW;
      SysCtrlRegs.PLLSTS.bit.MCLKOFF = 0;
      EDIS;
    // If switching to 1/2
if((divsel == 1)||(divsel == 2))
  EALLOW;
     SysCtrlRegs.PLLSTS.bit.DIVSEL = divsel;
     EDIS;
// If switching to 1/1
// * First go to 1/2 and let the power settle
//   The time required will depend on the system, this is only an example
// * Then switch to 1/1
if(divsel == 3)
  EALLOW;
     SysCtrlRegs.PLLSTS.bit.DIVSEL = 2;
     DELAY_US(50L);
     SysCtrlRegs.PLLSTS.bit.DIVSEL = 3;
     EDIS;
复制代码
      如果我们希望DSP工作在某一个频率下,我们就可以对Uint16 val, Uint16 divsel两个参数进行设定。
isseed 发表于 2016-6-30 22:42 | 显示全部楼层
这个不是直接初始化完成的吗
isseed 发表于 2016-6-30 22:43 | 显示全部楼层
楼主的配置都是什么
isseed 发表于 2016-6-30 22:46 | 显示全部楼层
我们如何修改自己想要的频率呢
以灬初 发表于 2017-5-4 14:50 | 显示全部楼层
