[i.MX] yocto工程出错: sdl configure was not able to find it
2956|1
 楼主| sara_yihao 发表于 2016-7-1 11:28 | 显示全部楼层 |阅读模式
bitbake fsl-image-gui时,会出现以下错误:
ERROR: Function failed: do_configure (log file is located at /home/zhang149/fsl-imx6ul-bsp/buil-gui/tmp/work/x86_64-linux/qemu-native/2.4.0-r1/temp/log.do_configure.14368)
ERROR: Logfile of failure stored in: /home/zhang149/fsl-imx6ul-bsp/buil-gui/tmp/work/x86_64-linux/qemu-native/2.4.0-r1/temp/log.do_configure.14368
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function autotools_preconfigure
| DEBUG: Shell function autotools_preconfigure finished
| DEBUG: Executing python function autotools_copy_aclocals
| DEBUG: Python function autotools_copy_aclocals finished
| DEBUG: Executing shell function do_configure
| ERROR: User requested feature sdl
|        configure was not able to find it.
|        Install SDL devel
| WARNING: exit code 1 from a shell command.
似乎是SDL相关的问题,该如何解决?
 楼主| sara_yihao 发表于 2017-2-23 09:25 | 显示全部楼层
木有人理,还好自行解决了~结贴
