[STM8] 询问STM8L驱动24位ADTM7707初始化通讯问题
1822|2
 楼主| 别轻易靠近我 发表于 2016-7-4 15:40 | 显示全部楼层 |阅读模式
最近在调TM7707这块芯片,有大神用过这块芯片吗,这是我的初始化程序大家帮忙看看哪里出问题了:
void TM7707_init(void)
  SCLK1_H();
  DIN1_H();
  udelay(1);
  write_byte(0x50);
  write_byte(0x00);
  udelay(1);
  write_byte(0x20);
  write_byte(0x03);
  udelay(1);
//  write_byte(0x10);
//  write_byte(0x04);
  write_byte(0x10);
  write_byte(0x44);
  while(DRDY);
void write_byte(u8 data)
  u8 i;
  for(i=0; i<8; i++)
    SCLK1_L();
    udelay(1);
    if((data & 0x80))
      DIN1_H();
    else
      DIN1_L();
    SCLK1_H();
    data <<= 1;
u8 read_data(void)
  u8 j = 0, rdata = 0;
  u8 doutbit = 0;
  for(j=0; j<8; j++)
    SCLK1_L();
    udelay(1);
    if(DOUT == RESET)
      doutbit = 0;
    else
      doutbit = 1;
    rdata = ((rdata << 1)| doutbit);
    SCLK1_H();
  return rdata;
uint32_t read_ch1_result(void)
  u32 tm_result = 0, a[3] = {0};
  u8 sum[10] = { 0 };
  u8 i = 0,flag = 0;
  static u32 k = 0;
    while(DRDY != RESET);
    write_byte(0x38);
    for(i=0; i<3; i++)
      a[i] = read_data();
   tm_result = a[0] + (a[1] * 256) + (a[2] * 65536);
   return tm_result;
mmuuss586 发表于 2016-7-4 19:56 | 显示全部楼层
没用过呢;
初步看没啥问题啊,你用示波器看下时序,记录下来,和DATASHEET对比下,哪里出问题了;
12386 发表于 2022-9-25 19:56 | 显示全部楼层
正在找TM7707应用资料
