[STM32F1] 求助关于STM32F1驱动12864液晶,单行反白显示问题
1305|2
 楼主| ben_wu 发表于 2016-7-4 15:59 | 显示全部楼层 |阅读模式
反白程序如下:
u8 const Lcd_Con_X_Y[4][2]={{0x80,0x80},{0x80,0x90},{0x88,0x80},{0x88,0x90}};
void con_disp (unsigned int line,unsigned int enable)
  u8 i,j;
  for(j=0;j<16;j++)
    for(i=0;i<8;i++)
              Write_LCD_Command(0x36);
              Write_LCD_Command(Lcd_Con_X_Y[line][1]+j);
              Write_LCD_Command(Lcd_Con_X_Y[line][0]+i);
              Write_LCD_Command(0x30);
                if(enable==1)
                      Write_LCD_Data(0xff);
                else
                      Write_LCD_Data(0x00);
void con_disp8(unsigned int x,unsigned int y,unsigned int direction)
        u8 j;
          for(j=0;j<16;j++)
              Write_LCD_Command(y+j);
              Write_LCD_Command(x);
                if(direction==1)
                      Write_LCD_Data(0xFF);
                else
抄的网友的单行反白和单个字符反白,均无**常显示,求教各位论坛高手!
mmuuss586 发表于 2016-7-4 20:14 | 显示全部楼层
是不是背光没调好呢
 楼主| ben_wu 发表于 2016-7-5 14:06 | 显示全部楼层
是不是背光没调好呢
不是的,已经搞定咯。加了清除画图去ram的命令。
