[PIC®/AVR®/dsPIC®产品] MPLAB 编译问题Error - could not find file 'c018i.o'.
2311|2
 楼主| 老麻烦了 发表于 2016-7-12 16:32 | 显示全部楼层 |阅读模式
Make: The target "C:\Users\Administrator\Desktop\877A\TLY.o" is out of date.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F2525 "TLY.c" -fo="TLY.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Make: The target "C:\Users\Administrator\Desktop\877A\TLY.cof" is out of date.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPLink.exe" /p18F2525 "..\..\..\..\MCC18\lkr\18f2525.lkr" "TLY.o" /u_CRUNTIME /u_DEBUG /o"TLY.cof" /M"TLY.map" /W
MPLINK 4.41, Linker
Device Database Version 1.5
Copyright (c) 1998-2011 Microchip Technology Inc.
Errors    : 1
Link step failed.
求大神解答,谢谢!!!
JY-DX-JY 发表于 2016-7-12 18:05 | 显示全部楼层
百度应该可以找到答案
wuhenyouyu 发表于 2016-7-13 09:27 | 显示全部楼层
编译器版本不兼容,我遇到过。不过你的问题不清楚是不是这个导致的。
