[STM32F1] TIM1产生6路PWM波不出波形!!!求指导
1188|8
 楼主| ZHOU@JIE 发表于 2016-7-23 21:58 | 显示全部楼层 |阅读模式
求助。。。。。。。。。。
  1. #include "stm32f10x.h"
  2. #include "pwm.h"
  3. void TIM1_GPIO_Configuration(void)
  4. {
  5.         GPIO_InitTypeDef GPIO_InitStructure;
  6.         GPIO_PinRemapConfig(GPIO_FullRemap_TIM1,ENABLE);
  7.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOE|RCC_APB2Periph_TIM1,ENABLE);
  8.         GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
  9.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
  10.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  11.         GPIO_Init(GPIOE,&GPIO_InitStructure);
  12. }
  13. void TIM1_MODE_Configuration(void)
  14. {
  15.         TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
  16.         TIM_OCInitTypeDef TIM_OCInitStructure;
  17.         TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
  18.         TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  19.         TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_CenterAligned1;
  20.         TIM_TimeBaseInitStructure.TIM_Period=999;
  21.         TIM_TimeBaseInitStructure.TIM_Prescaler=71;
  22.         TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0;
  23.         TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
  24.         TIM_ARRPreloadConfig(TIM1, ENABLE);
  25.
  26.         TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
  27.         TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;
  28.         TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  29.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  30.         TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  31.         TIM_OCInitStructure.TIM_Pulse=500;
  32.         TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  33.         TIM_OC1Init(TIM1,&TIM_OCInitStructure);
  34.         TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);
  35.
  36.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  37.         TIM_OCInitStructure.TIM_Pulse=375;
  38.         TIM_OC2Init(TIM1,&TIM_OCInitStructure);
  39.         TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);
  40.
  41.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  42.         TIM_OCInitStructure.TIM_Pulse=250;
  43.         TIM_OC3Init(TIM1,&TIM_OCInitStructure);
  44.         TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable);
  45.
  46.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  47.         TIM_OCInitStructure.TIM_Pulse=125;
  48.         TIM_OC4Init(TIM1,&TIM_OCInitStructure);
  49.         TIM_OC4PreloadConfig(TIM1,TIM_OCPreload_Enable);
  50.
  51.         TIM_ARRPreloadConfig(TIM1,ENABLE);
  52.         TIM_Cmd(TIM1,ENABLE);
  53.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  54. }
mmuuss586 发表于 2016-7-23 23:22 | 显示全部楼层
                TIM_CCPreloadControl(TIM1, ENABLE);
                TIM_ITConfig(TIM1, TIM_IT_COM, ENABLE);
加上这2句看下;
734774645 发表于 2016-7-24 08:33 | 显示全部楼层
不知道楼上的对不对,楼主试了没。
 楼主| ZHOU@JIE 发表于 2016-7-24 22:53 | 显示全部楼层
不知道楼上的对不对,楼主试了没。
不需要后面的两句话也可以。试过了。
恩,问题解决了,是我调用的时候出了问题。谢谢了。
734774645 发表于 2016-7-29 23:41 | 显示全部楼层
产生的路是相同的,还是独立的,还是互补的三对?
 楼主| ZHOU@JIE 发表于 2016-7-30 15:14 | 显示全部楼层
互补,现在波形有了但是在中断中如何实时改变占空比呢?
Bjorn 发表于 2016-7-31 20:05 | 显示全部楼层
是不是改变TIM_OCInitStructure.TIM_Pulse的值啊
Soraka 发表于 2016-7-31 20:59 | 显示全部楼层
几个PWM是独立的吗
