PMM_unlockLPM5(); 函数会跑死,程序跑飞。
2641|8
 楼主| baici513 发表于 2016-7-24 16:59 | 显示全部楼层 |阅读模式
芯片:msp430FR5849
仿真器:TI 5969开发板 SBW
UART芯片: PL2303
开发环境:IAR 6.4
现象:  MSP430每次都能进入下载仿真,但会经常出现以下问题:
        1)  初始换GPIO,调用“PMM_unlockLPM5()”会仿真跑死,特别是初始化GPIO为中断输入的时候(port1、port2);
        2) 仿真的时候,程序不能跑动到断点,会经常性跑飞;
求各位大神指点一二,小弟不胜感激。
 楼主| baici513 发表于 2016-7-24 17:03 | 显示全部楼层
GPIO初始化代码如下 :
    GPIO_setAsOutputPin(GPIO_PORT_P1,GPIO_PIN7);
    GPIO_setOutputHighOnPin(GPIO_PORT_P1, GPIO_PIN7);
//    GPIO_setOutputLowOnPin(GPIO_PORT_P1, GPIO_PIN7);
    GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1, GPIO_PIN0);
    PMM_unlockLPM5();
    //SPI
    GPIO_setAsOutputPin(GPIO_PORT_P3,GPIO_PIN0 + GPIO_PIN2 +GPIO_PIN3);
    GPIO_setAsInputPin(GPIO_PORT_P3,GPIO_PIN1);
    GPIO_setOutputHighOnPin(GPIO_PORT_P3, GPIO_PIN0 + GPIO_PIN2 +GPIO_PIN3);
    PMM_unlockLPM5();
    GPIO_setAsOutputPin(GPIO_PORT_P4,GPIO_PIN4);
    GPIO_setOutputHighOnPin(GPIO_PORT_P4, GPIO_PIN4);
    PMM_unlockLPM5();
    //SPI
    GPIO_setAsOutputPin(GPIO_PORT_P3, GPIO_PIN4 + GPIO_PIN5 + GPIO_PIN6 + GPIO_PIN7);
    GPIO_setOutputHighOnPin(GPIO_PORT_P3, GPIO_PIN4 + GPIO_PIN5 + GPIO_PIN6 + GPIO_PIN7);
    GPIO_setAsOutputPin(GPIO_PORT_P1, GPIO_PIN6);
    GPIO_setOutputHighOnPin(GPIO_PORT_P1, GPIO_PIN6);
    PMM_unlockLPM5();
    GPIO_setAsOutputPin(GPIO_PORT_P2,GPIO_PIN3);
    GPIO_setOutputHighOnPin(GPIO_PORT_P2, GPIO_PIN3);
//    GPIO_setOutputLowOnPin(GPIO_PORT_P2, GPIO_PIN3);
    PMM_unlockLPM5();
    Gpio_IrqInit(GPIO_PORT_P2, GPIO_PIN7, GPIO_HIGH_TO_LOW_TRANSITION);
//    Gpio_IrqInit(GPIO_PORT_P1, GPIO_PIN0, GPIO_HIGH_TO_LOW_TRANSITION);
    Gpio_IrqInit(GPIO_PORT_P1, GPIO_PIN1 + GPIO_PIN2, GPIO_HIGH_TO_LOW_TRANSITION);
    Gpio_IrqInit(GPIO_PORT_P1, GPIO_PIN2, GPIO_HIGH_TO_LOW_TRANSITION);
 楼主| baici513 发表于 2016-7-24 17:15 | 显示全部楼层
补充下IO中断初始化函数,刚刚搞掉了
/*GPIO中断初始化*/
static void Gpio_IrqInit(uint8_t selectedPort,uint16_t selectedPins,uint8_t edgeSelect)
       //Enable Px.x internal resistance as pull-Up resistance
        GPIO_setAsInputPinWithPullUpresistor(
                selectedPort,
                selectedPins
        //Px.x interrupt enabled
        GPIO_enableInterrupt(
                selectedPort,
                selectedPins
        //Px.x Hi/Lo edge
        GPIO_interruptEdgeSelect(
                selectedPort,
                selectedPins,
                edgeSelect
        //P1.4 IFG cleared
        GPIO_clearInterruptFlag(
                selectedPort,
                selectedPins
         * Disable the GPIO power-on default high-impedance mode to activate
         * previously configured port settings
        PMM_unlockLPM5();
youtome 发表于 2016-7-24 22:36 | 显示全部楼层
怎么不使用看门狗。
youtome 发表于 2016-7-24 22:39 | 显示全部楼层
程序跑飞肯能是内部的空间太大了。
 楼主| baici513 发表于 2016-7-25 13:53 | 显示全部楼层
怎么不使用看门狗。
程序还在调试阶段啊 ,肯定不适用看门狗啊
 楼主| baici513 发表于 2016-7-25 13:54 | 显示全部楼层
程序跑飞肯能是内部的空间太大了。
能说得具体点么?  不太明白
lihuami 发表于 2016-7-25 22:21 | 显示全部楼层
初始换GPIO?程序就跑飞?
lihuami 发表于 2016-7-25 22:23 | 显示全部楼层
你试试自己配置寄存器。
