【21ic分享赛】+光纤通信模块 软件
1370|0
 楼主| 风去 发表于 2016-7-30 08:22 | 显示全部楼层 |阅读模式
CAN发送函数与CAN接收函数:
void CAN0SendFrame(CAN_MESSAGE Msg/*, unsigned long id,unsigned char length,unsigned char *txdata */)
          INT8U index;                          /*number for read message*/
          INT8U tbsel ;                      /* symbol for CAN0TBSEL*/
          CAN0TBSEL = CAN0T**;                 /* Select lowest empty buffer */
          tbsel = CAN0TBSEL;                                /* Backup selected buffer  */
          *((INT32U *) ((INT32U)(&CAN0TXIDR0)))= Msg.ulID.ulVal; /*lint !e923  MISRA 2004 Rule 11.3 cast from pointer to unsigned long*/
          if(Msg.ubLen > 8U)
              Msg.ubLen = 8U;
          for (index = 0U;index < Msg.ubLen; index++)
             *(&CAN0TXDSR0 + index) = Msg.ubData[index];    /*  Load data to Tx buffer  Data Segment Registers(ONLY 8 BYTES?) */
          CAN0TXDLR  = Msg.ubLen;                          /* Set Data Length Code  */
          CAN0TXTBPR = 0U;                               /* Set Priority          */
          CAN0T**   = tbsel;                                     /* Start transmission    */
/* NOTE: The routine should include the following actions to obtain
       correct functionality of the hardware.
      The ISR is invoked by RXF flag. The RXF flag is cleared
      if a "1" is written to the flag in CAN0R** register.
      Example: CAN0R** = CAN0R**_RXF_MASK;
void CAN0_RX_ISR_Handler(void)
          if(CAN0R**_RXF)   /*接收缓冲区满 */
                if(g_can0RxBuf.RxCounter < CAN0_RXBUF_SIZE)
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ulID.ubDB[0] =  CAN0RXIDR0; /*ID */
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ulID.ubDB[1] =  CAN0RXIDR1 ;
                #if BMS_CAN0_IDE > 0
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ulID.ubDB[2] =  CAN0RXIDR2;
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ulID.ubDB[3] =  CAN0RXIDR3 ;
            #endif
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ubData[0] = CAN0RXDSR0; /*Data */
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ubData[1] = CAN0RXDSR1;
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ubData[2] = CAN0RXDSR2;
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ubData[3] = CAN0RXDSR3;
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ubData[4] = CAN0RXDSR4;
                g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ubData[5] = CAN0RXDSR5;
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ubData[6] = CAN0RXDSR6;
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ubData[7] = CAN0RXDSR7;
                    g_can0RxBuf.Msg[g_can0RxBuf.RxInptr].ubLen = CAN0RXDLR & 0x0fU;         /*Length */
                    g_can0RxBuf.RxInptr ++;
                    if(g_can0RxBuf.RxInptr >= CAN0_RXBUF_SIZE)
                              g_can0RxBuf.RxInptr = 0U;
                    g_can0RxBuf.RxCounter ++ ;
           rte_release_Semaphore(rte_can0_MsgRxSem);
           CAN0R**_RXF = 1U;/*清中断标志*/
