[DSP编程] 有关DSP仿真器驱动安装正确。但仿真器无法连接的问题的处理方法
3134|1
 楼主| yuancanghu 发表于 2016-8-3 16:55 | 显示全部楼层 |阅读模式
仿真器驱动,发现安装正确。但仿真器无法连接,CCS显示错误代码:
Error connecting to the target: Error 0x80000240/-155 Fatal Error during: Initialization, OCS,
This error was generated by TI's USCIF driver.  SC_ERR_POD_NO_LIBRARY <-155> This utility cannot find the adapter for a custom emulator. The adapter can be named in a board config file.   Sequence ID: 0 Error Code: -155 Error Class: 0x80000240
需要这样做:
1.找到仿真驱动器的安装文件夹C:\DevTools\CCStudio_v3.3PLA\cc\bin,
2.拷贝驱动安装文件夹里的XDS510U2.dll文件拷贝至C:\DevTools\CCStudioV3.3\cc\bin目录下.问题解决。
注:C:\DevTools\CCStudio_v3.3PLA\cc\bin与C:\DevTools\CCStudioV3.3为我的仿真器驱动安装目录和css3.3安装目录
zhangmangui 发表于 2016-8-3 21:41 | 显示全部楼层
非常感谢你的分享
