这个IC的AAM和SYNC功能有什么用的?
2577|1
 楼主| 电子0 发表于 2016-8-5 15:33 | 显示全部楼层 |阅读模式
ic, AN, ce, AD, ofo
1脚:AAM——Advanced Asynchronous Modulation. Connect the tap of 2 resistor dividers to force the
MP1495 into non-synchronous mode under light loads. Drive AAM pin high (VCC) to
force the MP1495 into CCM.
6脚:SYNC——Apply an external clock to the EN
pin to change the switching frequency.
lyjian 发表于 2016-8-5 21:48 | 显示全部楼层
AAM调轻载进入点(轻载效率)
SYNC调开关频率
