[其它应用] 为什么进不了流水灯程序
734|0
 楼主| zhanglli 发表于 2016-8-6 11:01 | 显示全部楼层 |阅读模式
                   ORG                   0000H
                   AJMP                  START
                   ORG                   0080H
START:             MOV        SP,        #60H
                   NOP
                   NOP
                   NOP
                   NOP
                   NOP
                   MOV        P0CR,      #01000111B  ;设置为输出方式
                   MOV        P1CR,      #00000011B
                   MOV        P2CR,      #01100000B
                   MOV        P3CR,      #00110100B
LOOP_1:            MOV        R4,        #6          ;LED闪烁6次
                   MOV        P0,        #01000111B  ;口置为高电平灯全亮
                   MOV        P1,        #00000011B
                   MOV        P2,        #01100000B
                   MOV        P3,        #00110100B
                   ACALL                 DELAY_1S    ;延时
LOOP:              CPL                   P0.6        ;输出低电平灯全亮
                   CPL                   P0.2
                   CPL                   P0.1
                   CPL                   P0.0
                   CPL                   P1.0
                   CPL                   P1.1
                   CPL                   P2.6
                   CPL                   P2.5
                   CPL                   P3.5
                   CPL                   P3.4
                   CPL                   P3.2
                   ACALL                 DELAY_1S     ;延时
                   DJNZ       R4,        LOOP         ;6次未到返回再次执行
                   CLR                   P0.6         ;6次到口输出低电平灯全灭
                   CLR                   P0.2
                   CLR                   P0.1
                   CLR                   P0.0
                   CLR                   P3.5
                   CLR                   P3.4
                   CLR                   P3.2
                   CLR                   P2.5
                   CLR                   P2.6
                   CLR                   P1.1
                   CLR                   P1.0
                   ACALL                 DELAY_1S     ;延时进入流水灯程序段
                   SETB                  P0.6
                   SETB                  P3.5
                   ACALL                 DELAY_1S
                   CLR                   P3.5
                   SETB                  P2.5
                   ACALL                 DELAY_1S
                   CLR                   P2.5
                   SETB                  P2.6
                   ACALL                 DELAY_1S
                   CLR                   P2.6
                   SETB                  P3.2
                   ACALL                 DELAY_1S
                   CLR                   P3.2
                   SETB                  P1.1
                   ACALL                 DELAY_1S
                   CLR                   P1.1
                   SETB                  P1.0
                   ACALL                 DELAY_1S
                   CLR                   P1.0
                   SETB                  P3.4
                   ACALL                 DELAY_1S
                   CLR                   P0.6
                   CLR                   P3.4
                   ACALL                 DELAY_1S
                   SETB                  P0.2
                   SETB                  P3.5
                   ACALL                 DELAY_1S
                   CLR                   P3.5
                   SETB                  P2.5
                   ACALL                 DELAY_1S
                   CLR                   P2.5
                   SETB                  P2.6
                   ACALL                 DELAY_1S
                   CLR                   P2.6
                   SETB                  P3.2
                   ACALL                 DELAY_1S
                   CLR                   P3.2
                   SETB                  P1.1
                   ACALL                 DELAY_1S
                   CLR                   P1.1
                   SETB                  P1.0
                   ACALL                 DELAY_1S
                   CLR                   P1.0
                   SETB                  P3.4
                   ACALL                 DELAY_1S
                   CLR                   P0.2
                   CLR                   P3.4
                   ACALL                 DELAY_1S
                   SETB                  P0.1
                   SETB                  P3.5
                   ACALL                 DELAY_1S
                   CLR                   P3.5
                   SETB                  P2.5
                   ACALL                 DELAY_1S
                   CLR                   P2.5
                   SETB                  P2.6
                   ACALL                 DELAY_1S
                   CLR                   P2.6
                   SETB                  P3.2
                   ACALL                 DELAY_1S
                   CLR                   P3.2
                   SETB                  P1.1
                   ACALL                 DELAY_1S
                   CLR                   P1.1
                   SETB                  P1.0
                   ACALL                 DELAY_1S
                   CLR                   P1.0
                   SETB                  P3.4
                   ACALL                 DELAY_1S
                   CLR                   P0.1
                   CLR                   P3.4
                   ACALL                 DELAY_1S
                   SETB                  P0.0
                   SETB                  P3.5
                   ACALL                 DELAY_1S
                   CLR                   P3.5
                   SETB                  P2.5
                   ACALL                 DELAY_1S
                   CLR                   P2.5
                   SETB                  P2.6
                   ACALL                 DELAY_1S
                   CLR                   P2.6
                   SETB                  P3.2
                   ACALL                 DELAY_1S
                   CLR                   P3.2
                   SETB                  P1.1
                   ACALL                 DELAY_1S
                   CLR                   P1.1
                   SETB                  P1.0
                   ACALL                 DELAY_1S
                   CLR                   P1.0
                   SETB                  P3.4
                   ACALL                 DELAY_1S
                   CLR                   P0.0
                   CLR                   P3.4
                   ACALL                 DELAY_1S
                   AJMP                  LOOP_1       ;进入下一个循环
DELAY_1S:          MOV          R7,      #7FH
DL1:               MOV          R6,      #0EBH
DL0:               MOV          R5,      #20H
                   DJNZ         R5,      $
                   DJNZ         R6,      DL0
                   DJNZ         R7,      DL1
                   NOP
                   RET
                   END
