温度传感器查表
1269|3
 楼主| lhx117 发表于 2016-8-11 10:30 | 显示全部楼层 |阅读模式
code unsigned int ad_dt[91]={0xbd8,0xbb4,0xb8e,0xb68,0xb42,0xb1b,0xaf4,0xacc,0xaa4,0xa7c,0xa53,0xa2b,0xa02,0x9d8,0x9af,0x986,0x95c,0x933,0x909,0x8e0,0x8b7,
        0x88e,0x865,0x83c,0x813,0x7eb,0x7c3,0x79c,0x774,0x74e,0x727,0x701,0x6db,0x6b6,0x691,0x66d,0x649,0x626,0x604,0x5e1,0x5c0,
        0x59f,0x57e,0x55e,0x53f,0x520,0x502,0x4e4,0x4c7,0x4aa,0x48f,0x473,0x458,0x43e,0x424,0x40b,0x3f2,0x3da,0x3c3,0x3ac,0x395,
        0x37f,0x36a,0x355,0x340,0x32c,0x318,0x305,0x2f3,0x2e0,0x2ce,0x2bd,0x2ac,0x29c,0x28b,0x27c,0x26c,0x25d,0x24f,0x240,0x232,
        0x225,0x218,0x20b,0x1fe,0x1f2,0x1e6,0x1da,0x1cf,0x1c4,0x1b9};
传感器接地,通过5.1k接到vcc
mcu5i51 发表于 2016-8-11 11:19 | 显示全部楼层
什么东东,表示看不懂
ddllxxrr 发表于 2016-8-12 05:32 | 显示全部楼层
楼主是不是程序没有发全啊???
airwill 发表于 2016-8-12 07:39 | 显示全部楼层
这是个数组, 就是个表格, 看样子是不同温度下的传感器数值,
通常这种表格是通过传感器的数值查到值在表格中的位置, 就是对应的温度值吧
