[应用相关]
关于PWM输入捕捉
1543|7
laozhongyi|  楼主 | 2016-8-13 11:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PWM, TI, ic, pi, IO
大家好,最近在做一个项目关于PWM输入捕捉的,使用的单片机为STM8S105,我在用STM8的输入捕捉功能 利用库函数TIME1 CH1 捕捉PE0的频率 很准,但是我在此程序基础上将PE0口的频率 改为由 TIME2 产生,同样使用TIME1 CH1 捕捉,捕捉到的频率不对是怎么回事? TIME2 产生的PWM 用示波器测试很准的 望高手指点,谢谢!!!!!!
库函数捕捉程序如下:
void main(void)
  TIM1_Channel = TIM1_CHANNEL_1
  TIM1_ICPolarity = TIM1_ICPOLARITY_FALLING
  TIM1_ICSelection = TIM1_ICSELECTION_DIRECTTI
  TIM1_ICPrescaler = TIM1_ICPSC_DIV8
  TIM1_ICFilter = 0x0
  TIM1_ICInit( TIM1_CHANNEL_1, TIM1_ICPOLARITY_FALLING, TIM1_ICSELECTION_DIRECTTI,  TIM1_ICPSC_DIV8, 0x0);
  TIM1_ITConfig(TIM1_IT_CC1, ENABLE);
   /* Enable TIM1 */
  TIM1_Cmd(ENABLE);
   /* Clear CC1 Flag*/
  TIM1_ClearFlag(TIM1_FLAG_CC1);
   /* Connect LSI to COO pin*/
  GPIO_Init(GPIOE, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);
  CLK_CCOConfig(CLK_OUTPUT_LSI);
  CLK_CCOCmd(ENABLE);
  /* wait a capture on CC1 */
  while((TIM1->SR1 & TIM1_FLAG_CC1) != TIM1_FLAG_CC1);
  /* Get CCR1 value*/
        ICValue1 = TIM1_GetCapture1();
        /* wait a capture on cc1 */
  /* Get CCR1 value*/
        ICValue2 = TIM1_GetCapture1();
  /* Compute LSI clock frequency */
  LSIClockFreq = (8 * TIM1ClockFreq) / (ICValue2 - ICValue1);
/* Insert a break point here */
        while (1);
在此库函数基础上,改为TIME2产生PWM程序如下,
void init_hsiclk(void)
CLK_DeInit(); //寄存器复位
CLK_HSICmd(ENABLE); //内部高速时钟使能
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //内部分频 2M
void TIM2_init(void)
  TIM2_TimeBaseInit(TIM2_PRESCALER_16, 6665);
  TIM2_OC3Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,CCR3_Val, TIM2_OCPOLARITY_HIGH);
  TIM2_OC3PreloadConfig(ENABLE);
  TIM2_ARRPreloadConfig(ENABLE);
  TIM2_Cmd(ENABLE);
void main(void)
  //CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);//主时钟16/16=1MHZ   4分频
        init_hsiclk();
        GPIO_Init(TIME2PWMOUT_PORT, TIME2PWMOUT_PIN , GPIO_MODE_OUT_PP_LOW_FAST);     //设置PA3端口为推挽输出模式
        GPIO_Init(TIME1PWMIN_PORT , TIME1PWMIN_PIN, GPIO_MODE_IN_FL_NO_IT);
  TIM2_init();
        /* Enable CC1 interrupt */
        /* Enable TIM1 */
  TIM1_Cmd(ENABLE);
        /* Clear CC1 Flag*/
//GPIO_Init(GPIOE, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);    //不使用
        //CLK_CCOConfig(CLK_OUTPUT_LSI);
        //CLK_CCOCmd(ENABLE);
  /* Get CCR1 value*/
  /* Get CCR1 value*/
        while (1);
Edisons| | 2016-8-13 12:14 | 只看该作者
学习下,感觉还是挺不错的呀!!!
_gege| | 2016-8-13 12:20 | 只看该作者
要是有解释说明就更好了
Mozarts| | 2016-8-13 12:28 | 只看该作者
使用TIME1 CH1 捕捉,捕捉到的频率不对??楼主有没进行对比呢??
Listate| | 2016-8-13 12:37 | 只看该作者
不知楼主是用来干嘛的呢??这个感觉很多地方有用到。。。
xia00| | 2016-8-13 12:45 | 只看该作者
论坛里很多的关于捕获问题和其解决方法。。
boy1990| | 2016-8-13 12:59 | 只看该作者
while((TIM1->SR1 & TIM1_FLAG_CC1) != TIM1_FLAG_CC1); 没记错的话这个主要用来定时等待。。
laozhongyi|  楼主 | 2016-8-14 18:26 | 只看该作者
不知道需要如何去对比呢??
