NXP的LPC175x/6x系列超频
2413|1
 楼主| huzixian 发表于 2010-3-19 10:37 | 显示全部楼层 |阅读模式
除了x9本身就是120M max,其他系列超频120M应该没有问题吧?
能测试的兄弟们搞一下?
The EEMBC certification lab has tested the microcontroller at 72,100, and 120 MHz (overclocked?), the performance and efficiency put down as a consequence of the memory architecture of the microcontroller.
或者想问问为什么x9是120M,而其他是100M,具体原因是?
linux1 发表于 2010-3-19 10:39 | 显示全部楼层
刚到了1768的小板,第一个任务就是超频,自己来做!
测试结果:
CCLK  FLASHCFG      IAR Performance(Loops/sec)
141.12MHz  6 clocks          8454
141.12Mhz  5 clocks          8466
72Mhz  5 clocks          4311
72Mhz  4 clocks          4318
结果发现FLASH等待周期数似乎影响不大?
确认 测试代码段在FLASH里: _CalcPrimes             0x0000076d   0x5c  Code  Lc  OS_PerformanceTest.o [1]
TEST METHOD:
File    : OS_PerformanceTest.c (medium optimize)
Purpose : Performance test program
          It checks the performance of the entire system, outputing one
          result value per second. Higher values are better.
          The program computes the first 1000 prime numbers in a loop.
          The value output is the number of times this could be performed
          in a second.
          Version 2.0, July-14 2008
Reference values -  RAM configuration:
ARM926-EJS fully chached, 201.0MHz, IAR EWARM V5.20, Thumb Mode => 11834 Loops/sec => 58.9 Loops/sec/MHz
ARM926-EJS fully chached, 201.0MHz, IAR EWARM V5.20, ARM   Mode => 12497 Loops/sec => 62.2 Loops/sec/MHz
ARM7-TDMI                  47.9MHz, IAR EWARM V5.20, Thumb Mode =>  2656 Loops/sec => 55.4 Loops/sec/MHz
ARM7-TDMI                  47.9MHz, IAR EWARM V5.20, ARM   Mode =>  2646 Loops/sec => 55.2 Loops/sec/MHz
