以下是相关代码: //pin
#define SPI_SCLK_PIN GPIO_Pin_10
#define SPI_MISO_PIN GPIO_Pin_11
#define SPI_MISI_PIN GPIO_Pin_12
#define SPI_GPIO_PORT GPIOC
#define SPI_GPIO_CS_PORT GPIOA
#define SPI_GPIO_CS_PIN GPIO_Pin_15
#define SPI_CS_LOW() GPIO_ResetBits(SPI_GPIO_CS_PORT,SPI_GPIO_CS_PIN) //Chip Select pin set low
#define SPI_CS_HIGH() GPIO_SetBits(SPI_GPIO_CS_PORT,SPI_GPIO_CS_PIN) //Chip Select pin set low
//command of AT25
#define CMD_AT25_READ_ID 0x9f
#define CMD_AT25_WRITE_ENABLE 0x06
#define CMD_AT25_PAGE_PROGRAME 0x02
#define CMD_AT25_READ_STATUSREGISTER 0x05
#define CMD_AT25_READ_ARRAY_1B 0x1b
#define CMD_AT25_READ_ARRAY_0B 0x0b
#define CMD_AT25_ERASE_4K 0x20
#define CMD_AT25_WRITE_STATUSREGISTER_BYTE1 0x01
* Description : Configure SPI GPIO
static void SPI_GPIO_Configuration(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
GPIO_StructInit(&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = SPI_SCLK_PIN | SPI_MISI_PIN | SPI_MISO_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(SPI_GPIO_PORT,&GPIO_InitStructure);
GPIO_PinAFConfig(SPI_GPIO_PORT, GPIO_PinSource10, GPIO_AF_SPI3);
GPIO_PinAFConfig(SPI_GPIO_PORT, GPIO_PinSource11, GPIO_AF_SPI3);
GPIO_PinAFConfig(SPI_GPIO_PORT, GPIO_PinSource12, GPIO_AF_SPI3);
GPIO_InitStructure.GPIO_Pin = SPI_GPIO_CS_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(SPI_GPIO_CS_PORT,&GPIO_InitStructure);
static void SPI_Configuration(void)
SPI_InitTypeDef SPI_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3,ENABLE);
SPI_Cmd(SPI3, DISABLE);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI3, &SPI_InitStructure);
SPI_Cmd(SPI3, ENABLE);
* Description : send data to AT25
static uint16_t SPI_FLASH_SendByte(uint16_t byte)
while (SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_TXE) == RESET);
SPI_I2S_SendData(SPI3, byte);
while (SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_RXNE) == RESET);
return SPI_I2S_ReceiveData(SPI3);
* Description : Read id of AT25
uint32_t Read_AT25_ID(void)
uint32_t at25_id = 0;
SPI_CS_LOW();
SPI_FLASH_SendByte(CMD_AT25_READ_ID);
at25_id = SPI_FLASH_SendByte(0xff);
SPI_CS_HIGH();
return at25_id;
* Description : Write Enable of AT25
static void SPI_FLASH_Write_Enable(void)
SPI_CS_LOW();
SPI_FLASH_SendByte(CMD_AT25_WRITE_ENABLE);
SPI_CS_HIGH();
static void SPI_FLASH_Page_Write(void)
SPI_FLASH_Write_Enable();
SPI_FLASH_WaitForWriteEnd();
SPI_CS_LOW();
SPI_FLASH_SendByte(CMD_AT25_PAGE_PROGRAME);
SPI_FLASH_SendByte(0x00);
SPI_FLASH_SendByte(0x01);
SPI_FLASH_SendByte(0x11);
SPI_FLASH_SendByte(0x1d);
SPI_CS_HIGH();
* Description : read the status register
static void SPI_FLASH_WaitForWriteEnd(void)
uint8_t FLASH_Status = 0;
SPI_CS_LOW();
SPI_FLASH_SendByte(CMD_AT25_READ_STATUSREGISTER);
do
FLASH_Status = SPI_FLASH_SendByte(0xff);
}while(FLASH_Status &0x01 == 0x01);
SPI_CS_HIGH();
