xds200 程序跑飞
3094|12
 楼主| olala_1984 发表于 2016-8-25 10:42 | 显示全部楼层 |阅读模式
大家好
我用XDS200仿真器  ,在ccs6.1 下 运行dsp28377D,
为什么时钟设置在50M以下的时候,能正常运行仿真,当时钟设置到50M以上时,程序烧进去,一点 运行,程序就跑飞掉了?
ccs报错如下:
C28xx_CPU1: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 6.0.222.0)
C28xx_CPU1: Trouble Halting Target CPU: (Error -1135 @ 0x82CD) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 6.0.222.0)
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
C28xx_CPU2: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 6.0.222.0)
C28xx_CPU2: Error: (Error -1135 @ 0x82CD) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 6.0.222.0)
C28xx_CPU2: Unable to determine target status after 20 attempts
C28xx_CPU2: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
chenci2013 发表于 2016-8-26 23:09 | 显示全部楼层
你用的什么的板子?
chenci2013 发表于 2016-8-26 23:11 | 显示全部楼层
看看你的仿真引脚的布线是不是一样长?
长的帅怪我落 发表于 2016-8-29 13:43 | 显示全部楼层
让程序飞一会把
chenci2013 发表于 2016-8-29 22:09 | 显示全部楼层
看看你的时钟怎么设置的
chenci2013 发表于 2016-8-29 22:12 | 显示全部楼层
你使用单步调试试试看。
zhangmangui 发表于 2016-8-29 23:02 | 显示全部楼层
问题解决了吗
尤彼卡 发表于 2016-8-30 17:16 | 显示全部楼层
时钟设置怎么会让程序飞呢?系统有哪些模块
comeon201208 发表于 2016-8-30 23:17 | 显示全部楼层
这个还要看下程序的关系到的目标板的MCU的
gygp 发表于 2016-9-3 11:21 | 显示全部楼层
gygp 发表于 2016-9-3 11:24 | 显示全部楼层
楼主这是用的什么芯片?
isseed 发表于 2016-9-4 22:43 | 显示全部楼层
是自己设计的开发板吗?
isseed 发表于 2016-9-4 22:44 | 显示全部楼层
程序跑飞是什么样的现象呢
