IO口测中断时间
1173|0
 楼主| houfei2002 发表于 2016-8-26 18:15 | 显示全部楼层 |阅读模式
IO, TE, dc, ADC, tc
<pre>
void timer1_ovf_isr(void)
        static unsigned char Ph0=0;
        //PORTB &=0xEF;
        TCNT1H = 0xE3;  //reload counter high value
        TCNT1L = 0xE1;  //reload counter low value
        PORTA=temp;
        temp<<=1;
        if(temp==0x00)
                temp=0x01;
        //PORTB |=0x10;
        switch(Ph0)
                case 0:
                        LED_TEST_H;
                        //PORTB &=0xEF;
                        Ph0 = 1;
                break;
                case 1:
                        LED_TEST_L;
                        //PORTB |=0x10;
                        Ph0 = 0;
                break;
                default:
                        Ph0 = 0;
用switch翻转PORTB 4正常,但是进中断清PORTB 4,出中断置高PORTB 4,程序跑起来PORTB 4一直低电平。
</pre>
