- MCU通过串口向电脑发送一串字符串
- #include <reg52.h>
- #define uchar unsigned char
- bit g_TranEnd = 1; //发送完毕标志
- void InitUart();
- void main()
- char *string = "I LOVE YOU!";
- InitUart();
- while ((*string != '\0') && (g_TranEnd == 1)) //当字符串不为‘\0'且发送完标志为1时进行发送
- g_TranEnd = 0;
- SBUF = *string++;
- void InitUart()
- TMOD &= 0x0F; //清空T1的控制位
- TMOD |= 0x20; //配置T1工作方式为2,即自动重装模式;
- TH1 = 0xFD; //晶振为11.0592MHZ,波特率为9600
- TL1 = TH1; //将TH1中的数据添加到TL1中
- PCON = 0x00; //波特率正常不倍增
- SCON = 0x50; //配置串口工作模式为1,且开启接收功能
- TR1 = 1; //串口的波特率发生器由T1(T2)产生,开启定时器T1;
- ES = 1; //开启串口中断
- EA = 1; //开启总中断
- void UartIRQ() interrupt 4
- if (1 == TI)
- TI = 0;
- g_TranEnd = 1;
